1968 Bbody Kframe in 1964/65 Bbody question
#1689318
10/22/14 09:02 PM
10/22/14 09:02 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
When fitting a 68 kframe in a 64/65 do you use the later idler arm or the correct year model item . The pitman arms , manual steer , appear to be the same . I do have a 68 steering box to use . I know the motor sets back about 1 1/2" . I presume header choice is not compromised . I am using a Milodon road race pan . If I do this I will look to fit heim joint strut rods at the same time Am I missing anything ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: 1968 Bbody Kframe in 1964/65 Bbody question
[Re: tex013]
#1689320
10/22/14 09:10 PM
10/22/14 09:10 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Unless you are using a motor plate that frame will move the motor in the wrong spot. It will move it forward about 1 1/2 in. Then you will have header fitment problems. Sorry read it wrong. You use 68 parts and 66 and later headers and a modified trans mount.
[Re: JAKE68]
#1689321
10/22/14 09:55 PM
10/22/14 09:55 PM
Posts: 437 south central pa
bdaz smblk
south central pa
It will move the motor back about 2 inches.Then if u run a 727 u just have to cut a small piece of the trans tunnel out for clearance.We did it to my dads 63 ply and it worked real nice.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: tex013]
#1689324
10/24/14 01:09 AM
10/24/14 01:09 AM
Posts: 1,443 Maryland
Dads426
Maryland
We did this swap on a 64 Plymouth about 6 years ago. Use the front end components from the year specific K-frame. The pinch weld in the tunnel will have to be flattened and you will need to use a BFH on the tunnel where the accumulator in the trans will contact the tunnel. Kick-down linkage, if used, can be made to work if you use the one-piece unit. The crossmember can be modified and use the cheaper 66 and later trans mount. 66 & later headers will work and a 66 and later oil pan will fit. Will post pics.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1689325
10/24/14 01:15 AM
10/24/14 01:15 AM
Dads426
Maryland
Trans mount. I mocked up a block and trans case in the car to get the correct position of the pocket for the mount.
[Re: Dads426]
#1689326
10/24/14 01:22 AM
10/24/14 01:22 AM
Dads426
Maryland
Bottom pic. Pocket is a piece of 2x3" rectangular tubing, boxed on the bottom.
[Re: Dads426]
#1689327
10/24/14 01:23 AM
10/24/14 01:23 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I have a 67 K frame in my 65 -
I have 66 up headers and a scatter shield - the clutch linkage is a perfect line up - goes right through the header opening.
My 6 cylinder b body 65 Z bar is a close fit as well.
I gutted a stock 65 trans cross member and have tacked in a trans mount out of a diplomat - I cut the metal out of the dippy trans mount and its a near perfect fit for the 65 cross member. I might have pics.
[Re: NTOLERANCE]
#1689328
10/24/14 01:35 AM
10/24/14 01:35 AM
NTOLERANCE
Madison Wi
When I went to replace and or check the pitman and idler arms - Napa listed the same part numbers for 65 and 67. Maybe they ahve it incorrect - but I would use the same years. Both of mine are early B body
[Re: NTOLERANCE]
#1689329
10/24/14 02:16 AM
10/24/14 02:16 AM
tex013
Sydney,Australia
thanks for the extra info and pics .
Tex
[Re: tex013]
#1689330
10/25/14 10:28 PM
10/25/14 10:28 PM
NTOLERANCE
Madison Wi
Gutted stock unit with diplomat center
