which block for a starting point ?? 400 or 440 #1689273
10/22/14 07:21 PM
10/22/14 07:21 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
Ready to start a new build for the 63 Dodge.....Horsepower goal is 650hp with 650 ft bs of torque..I have two blocks..A 1966 440 and a 1973 400 both perfect cores to begin with...Id like a reliable pump gas motor capable of low tens..Auto trans..4:30 geared Detroit Locker 8 3/4 rear with moser axles and cal tracs, super stock spring slightly inboard..
Would you build a big wedge motor using the low deck 400 or build the 440.??
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: which block for a starting point ?? 400 or 440 [Re: 72N96RR] #1689274
10/22/14 07:40 PM
10/22/14 07:40 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I'd go with the 400 blk. Stronger piece.
Re: which block for a starting point ?? 400 or 440 [Re: rickraw] #1689275
10/22/14 08:04 PM
10/22/14 08:04 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
X2 on 400 block
Re: which block for a starting point ?? 400 or 440 [Re: 451Cuda] #1689276
10/22/14 09:33 PM
10/22/14 09:33 PM
gregsdart Offline
gregsdart  Offline
hands down the 400. Stronger, lighter rotating assembly and final engine weight, more cores available, bigger bore to start with.
Re: which block for a starting point ?? 400 or 440 [Re: 72N96RR] #1689277
10/22/14 09:33 PM
10/22/14 09:33 PM
AndyF Offline
AndyF  Offline
Depends if you own any parts and what size the budget is. There are a lot more choices for RB intake manifolds. Headers can be a problem with B engines depending on the heads that you use.
My "go to" combo is a 440 block with a 4.25 crank and 6.80 long Chevy rods. That gives you a very foolproof 505 with fairly inexpensive parts. If you're using a standard head like an Edelbrock RPM then you can easily make 650/650 if you're willing to pay for porting. You'll want to build a zero deck engine with a bit of a dish to get the compression just right.
A big flat tappet cam should get you there and saves money over a roller setup.
Re: which block for a starting point ?? 400 or 440 [Re: 72N96RR] #1689278
10/22/14 11:35 PM
10/22/14 11:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
Your goals are easy to acheive with either block On pump gas my choice would be the 400 block based on having several 440 blocks that crack the main webs do to poor tuning on the owners part I also use to replace the main caps with The Mopar brand ductile iron and use main studs, the caps are no longer available from Mopar so aluminum or steel is the only choice now I just finished building a 440 stroker race motor with a similar combination, 4.350 bore with 4.300 stroke with 7.100 long Molnar steel H beam rods, for a customer using 440 Source aluminum main caps and there ARP main studs. No track time yet so no real feedback. The machine shop loved those caps, they fit right away and where easy to fit and finish IHTHs
Re: which block for a starting point ?? 400 or 440 [Re: AndyF] #1689279
10/23/14 12:33 AM
10/23/14 12:33 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The 400 block would be my choice. But like Andy said, what parts do you have. If you have all RB intakes and distributer stuff, then RB. If the other then B. If you have no parts besides the block, then the 400 for sure
Re: which block for a starting point ?? 400 or 440 [Re: Sport440] #1689280
10/23/14 02:06 AM
10/23/14 02:06 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used a 440 block on my mild 493. I had the 440 block and because of the intake choice it was just easier for me to go with the 440. And I only make about 600 flywheel hp but it was enough to make my goal of getting into the 10's on pump through the pipes at 3700 lbs. Its been in my 63 for just over 3 years and holding up fine and I drive the car alot. Ron
Re: which block for a starting point ?? 400 or 440 [Re: Sport440] #1689281
10/23/14 02:08 AM
10/23/14 02:08 AM
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
All the parts wee sold or given away...I just have the blocks..
Re: which block for a starting point ?? 400 or 440 [Re: 72N96RR] #1689282
10/23/14 03:01 AM
10/23/14 03:01 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The 400 makes more sense, but if you're going for a nostalgia look with that year of car, the RB fits a little better. Dressed up as a Max-wedge motor, it would look killer!
Re: which block for a starting point ?? 400 or 440 [Re: 72N96RR] #1689283
10/23/14 12:27 PM
10/23/14 12:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been trying to kill my 400 (470) for over 13 years.............
Re: which block for a starting point ?? 400 or 440 [Re: StealthWedge67] #1689284
10/23/14 03:49 PM
10/23/14 03:49 PM
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
A crossram isn't available for a low deck motor???
Re: which block for a starting point ?? 400 or 440 [Re: 72N96RR] #1689285
10/23/14 04:39 PM
10/23/14 04:39 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Only downside to the 400, imo, is there are alot less available intakes, both new & used. If you're going for a specific look definitely check into this.
Re: which block for a starting point ?? 400 or 440 [Re: 72N96RR] #1689286
10/23/14 05:55 PM
10/23/14 05:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you do it with ... gulp ... stage 6 heads on a 400 you can run an RB crossram.
Re: which block for a starting point ?? 400 or 440 [Re: JohnRR] #1689287
10/23/14 09:14 PM
10/23/14 09:14 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Didn't Edelbrock make an aftermarket crossram (STR??) for the B-motor??
Re: which block for a starting point ?? 400 or 440 [Re: Dean_Kuzluzski] #1689288
10/24/14 01:07 AM
10/24/14 01:07 AM
Yes they did, they where called Edlebrock STR intakes (Street Tunnel Rams) back in the early 1970s I put one on a 383 in a 1963 Dart, twin Holley 650 D.P., Isky 505 T soild roller cam and a stock converter, ignition and fuel system the owner had promised that he would buy a good converter,ignition, 4.56 gears, electric fuel pump and so on before I started building that motor on his project, he didn't My introduction to some custmers who are flakes I'm a little more selective and careful now on selecting customers to work with
Re: which block for a starting point ?? 400 or 440 [Re: Dean_Kuzluzski] #1689289
10/24/14 01:48 AM
10/24/14 01:48 AM
Puyallup, WA
Puyallup, WA
I believe you can find a cross-ram. But the motors just don't look the same. I love my 400 based 452, and it looks correct in my 383 car. A 63 M-W style car would just look right with the wide RB look between the fenders.
Re: which block for a starting point ?? 400 or 440 [Re: Dean_Kuzluzski] #1689290
10/24/14 04:32 PM
10/24/14 04:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes but ... A find one , ... B for a reasonable price. ... plus it doesn't look like a stock maxie intake.
Re: which block for a starting point ?? 400 or 440 [Re: JohnRR] #1689291
10/24/14 05:00 PM
10/24/14 05:00 PM
They definetily didn't look like a stock Mopar crossram They are a two piece intake with flat top that unbolts, 3 or 4 different tops fit the base
