I needed to pull the key lock assembly on a parts car I just picked up with no keys. After removal of the snap ring and three screws holding the collar I could not slip off the bearing so I could remove the collar to get access to push pin hole to release the mechanism. How do you deal with a bearing/bushing that will not budge? Car is a 71 Fury w/o tilt tele.
Billyfury 70-71 Fury collector
