Best roller lifter for Indy block #1689071
10/22/14 02:46 PM
10/22/14 02:46 PM
Oil City PA
1baddart Offline OP
1baddart  Offline OP
Oil City PA
What do u guys use for roller lifters? I have an indy block with no pushrods oiling, lifter bores are not drilled. I've used comp before but want something that will hold up a little better. Isky? Crower? What do think? Thanks!
Re: Best roller lifter for Indy block [Re: 1baddart] #1689072
10/22/14 04:05 PM
10/22/14 04:05 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Isky then Crower. Both are excellent. Just make sure they are the bushed/bronze bearing, not the roller bearing.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Best roller lifter for Indy block [Re: 1320Dart] #1689073
10/22/14 04:22 PM
10/22/14 04:22 PM
Oil City PA
1baddart Offline OP
1baddart  Offline OP
Oil City PA
I just talked to camfx. Has anyone ever used their lifters? Theyre a very high end lifter I think a lot of pro stocks and such use them.
Re: Best roller lifter for Indy block [Re: 1baddart] #1689074
10/22/14 04:26 PM
10/22/14 04:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think you will find a mixed bag with CamFX, at least I have. I have a set of them I will be listing for sale soon as we just went with Jesel Keyways to eliminate any issues.
All pro stock teams use Jesel. You may find a comp team or SS team using CamFX and the blown alky guys seem to like them.
IMO the Isky bushed EzROll's are hard o for most beat for most applications. The ones in the Cuda are well over 650 passes with no issues. Been back once for a lookse and about to go back again.
Re: Best roller lifter for Indy block [Re: 1baddart] #1689075
10/22/14 05:28 PM
10/22/14 05:28 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Most pro stocks run jesel lifters, Anderson line and Morgan in the cars and the Arronas in the bikes run cam fx lifters..... John force racing also runs cam fx stuff...
Re: Best roller lifter for Indy block [Re: boatracer572] #1689076
10/22/14 05:33 PM
10/22/14 05:33 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I have recently started using the Cam FX keyway lifters. To me the Jesel keyways have gotten to a ridiculous price and so far the Cam FX have been flawless for a lot less money
Al.......if your cam FX are .937 keyways, I would be intersted
Monte
Re: Best roller lifter for Indy block [Re: Monte_Smith] #1689077
10/22/14 06:10 PM
10/22/14 06:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Monte I agree 1000% on the Jesel prices. Just spent a bucket load on some cutom lifter bushings. The CamFX lifters I have are non key way tie bar stuff.
Re: Best roller lifter for Indy block [Re: Al_Alguire] #1689078
10/22/14 08:11 PM
10/22/14 08:11 PM
Oil City PA
1baddart Offline OP
1baddart  Offline OP
Oil City PA
Al I might be interested in your lifters. If u would pm the details on them. Thanks
