Anyone ever see ribbed air vents on a 66-67 Ply trunk #1688973
10/22/14 11:29 AM
10/22/14 11:29 AM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
I have a 66-67 Plymouth Belvadere/Sattelite/GTX trunk lid and it has these small gilled air vents on the top of the trunk lid. There are about 4 raised gills that look factory as I can't see where someone modified it to put these in. There are 2 sets of these. They are about 2 feet from each other in the middle of trunk. Are these factory or what? Also, is the 66 and 67 trunk lid the same and will it interchange?
Thnks,
Wizard
Guns, God, and Country. U.S. Veteran
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: Wizard] #1688974
10/22/14 01:16 PM
10/22/14 01:16 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
They are different, 66 has different (shorter and wider I believe) for the '66 reverse lights in the tail panel. You should be able to modify/cut either to work though.
And no that doesn't sound factory at all. Pics?
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: Wizard] #1688975
10/24/14 07:58 PM
10/24/14 07:58 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
pic 2
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: Wizard] #1688976
10/24/14 07:59 PM
10/24/14 07:59 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
pic 3
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: Wizard] #1688977
10/24/14 08:00 PM
10/24/14 08:00 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
pic 4. Can anyone tell if this is a 66 or 67 trunk?
Wizard
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: Wizard] #1688978
10/24/14 08:19 PM
10/24/14 08:19 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Dfinitely not factory. Why would they allow water or fumes in the trunk when they went so far to plug and seal all the holes with a deck lid seal, rubber floor plugs and taillight seals?
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: stumpy] #1688979
10/24/14 08:22 PM
10/24/14 08:22 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Yep...just added in/punched louvers someone did in the past.
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: OzHemi] #1688980
10/24/14 09:20 PM
10/24/14 09:20 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yeah no way its factory and thats a 67 lid
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: GTX MATT] #1688981
10/24/14 11:44 PM
10/24/14 11:44 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Thnks. They sure did nice body work though as you look at it close it looks factory.
Wizard
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: Wizard] #1688982
10/25/14 01:30 AM
10/25/14 01:30 AM
Grand Prairie,Texas
Grand Prairie,Texas
You can buy a louver tool on line.
Re: Anyone ever see ribbed air vents on a 66-67 Ply trunk [Re: stumpy] #1688983
10/25/14 11:55 AM
10/25/14 11:55 AM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Yes, the guy who just bought it said that's how they did it with a special stamp tool. Mostly they did it on hoods. old hot rodders. Said he was going to fix it when he bought it.
wizard
