Re: 5.7 Turbo in a A-body
[Re: mcat4321]
#1688958
10/22/14 03:50 PM
10/22/14 03:50 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
ok fella's i have a running driving N/A hemi in my 68 barracuda. i am looking to put a turbo on it this winter... so this post is awesome..i have a hemi denny tubular k frame so my set up is a little different. but i was looking at these. http://www.ebay.com/itm/Jeep-Grand-Chero...b3a&vxp=mtr i have tti now. i think a 180 bend out the rear to get the exhaust up front...just spitballing here
Dustin, they look like they might interfere with steering column. Not sure, if you get them I would love to know. they will have the d shape port too. crap, I want to buy them
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1688961
10/22/14 04:08 PM
10/22/14 04:08 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
i have a universal on my steering shaft half of it is inside the car, the other half is angled to the inner fender the dd is held there with a heim then aimed to the rack.. they should clear...
you might want to pull the trigger because I'm feeling frisky
go for it, i am in the early stage. then you can let us all know..
[Re: sixpackgut]
#1688962
10/22/14 04:12 PM
10/22/14 04:12 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Durango/Aspen are another possibility, and they can be had in Eagle port size.
Mopar to the bone!!!
[Re: dizuster]
#1688964
10/22/14 04:40 PM
10/22/14 04:40 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
why don't you just turbo a Magnum? I mean how much power do you want? Boost makes stupid power no matter the block.
LS is lighter w/high flowing factory heads and many will argue capable of much more abuse. There are many running 800+ HP with pretty much stock, high-mileage long blocks.
No doubt about that...and the same could be said with the LS vs. Gen 3 comparison too. But to Yuck's point... how much power do you need? If you're looking for sub 700hp, just about anything will work with a turbo.
I hear you. I'm not new to turbos. I built a turbo setup for the 440 in my 69 dart. I still have that engine and turbo setup that I could drop in my car, but I'd like something smaller and lighter. The low cost of the LS and available turbo exhaust is appealing to me. If I break it, I can simply pull another one from the yard for $350. I can't do that with my 440, which I believe is weaker than the LS anyways.
[Re: blowndart]
#1688965
10/22/14 05:03 PM
10/22/14 05:03 PM
72Swinger
Nebraska
Looks like the passenger side Durango/Aspen manifolds are the same as trucks. The drivers side are unique however. Here is an eBay item number of a driver's side Durango. 321405360723 check it out for yourself.
[Re: KRYPTONITE]
#1688966
10/22/14 11:50 PM
10/22/14 11:50 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
I ran into the same issues with my Dart. I wound up building my own headers. I work at a dealer and scoped out or tried on every possible factory manifold.....no way. So I cut the flanges off of a $100 set of headers I had and ordered a 1 3/4 header kit from Summit ($120) along with some V-bands and went to work. This was the first set of headers I have ever done. It took me about two weeks on and off to do them. The turned out pretty good (I think). There is simply no room on the drivers side for any other option. Take a look at my photobucket album. Take your time and plan ahead. Dave http://s1083.photobucket.com/user/swinger440/slideshow/
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: KRYPTONITE]
#1688971
11/30/14 07:26 PM
11/30/14 07:26 PM
mcat4321
cincinnati ohio
^^^^^^ Do you have a Pic of those on the block?
i will, i have them on my mock up block on an engine stand. i plan on documenting this process a lot with pics. i think with mild mod to the headers, they will work well on my build. i am making a bracket to move my alt. up and out 1 inch. an a/c compressor is most likely out of the question. my hot side will run to the front even with the oil pan rail under alt. and between oil filter adapter and frame then s up to turbo on pass. side up by radiator.. the driver side will run up pan rail where a/c comp. goes, then around belt, then 90* turn in front of balancer up to same turbo my hot side will be 2.25 stainless with a flex pipe on each bank . the downpipe will run parallel with valve cover between VP and inner fender turned down to follow trans. dip stick tube to under the car
[Re: mcat4321]
#1688972
11/30/14 07:57 PM
11/30/14 07:57 PM
mcat4321
cincinnati ohio
also remember, i have rack/pinion tube front end with home made mounts
