Page 2 of 3 1 2 3
Re: 5.7 Turbo in a A-body [Re: KRYPTONITE] #1688937
10/22/14 11:51 AM
10/22/14 11:51 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Just a question, why not just run a centrifical blower and a motor plate?
Then it is just cold side plumbing, off the shelf headers, etc
You could do a remote water pump and free up some room, use the multi rib serpentine balancer to drive it and a alternator.
"Just a Bracket car dressed up like a streetcar"
Re: 5.7 Turbo in a A-body [Re: Just-a-dart] #1688938
10/22/14 01:58 PM
10/22/14 01:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You don't have to run the oil lines there. You can use a regular ole remote filter adapter and screw it to the oil filter pad. Those block off plates are only necessary when using spool engine mounts.
Mopar to the bone!!!
Re: 5.7 Turbo in a A-body [Re: 72Swinger] #1688939
10/22/14 02:03 PM
10/22/14 02:03 PM
South Carolina
K
KRYPTONITE Offline OP
K
South Carolina
Yes sir, Im running the spool mounts so they will be used.
Re: 5.7 Turbo in a A-body [Re: Just-a-dart] #1688940
10/22/14 02:06 PM
10/22/14 02:06 PM
South Carolina
K
K
South Carolina
good point. but I already have the turbo for this setup and not sure I want to go to a centrifical blower,
Re: 5.7 Turbo in a A-body [Re: 72Swinger] #1688941
10/22/14 02:06 PM
10/22/14 02:06 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Admittedly I do not have an A-body, but an Early B-body is also pretty narrow. My stock magnum small block manifolds exit in nearly the EXACT same spot as the hemi manifolds. They kick outward towards the frame rail with both motors.
Small block is in the car and running, Hemi has already been mocked up for potential future replacement.
Just take your time, and plan out your hot side routing carefully... you'll be able to make it fit...
By the way... if it makes you feel any better, you're not dealing with any specific hemi problems... you're just dealing with general TURBO fabrication issues!
Re: 5.7 Turbo in a A-body [Re: superhog88] #1688942
10/22/14 02:07 PM
10/22/14 02:07 PM
South Carolina
K
K
South Carolina
there are a few ls turbo swaps where they used a rear facing drivers side manifold looped the exhaust down like a normal y-pipe but brought it up and into the back of a forward facing manifold on the passenger side
This has been my thought also, not gonna jump to the extreme until I see the fit mit with motor in there.
Re: 5.7 Turbo in a A-body [Re: dizuster] #1688943
10/22/14 02:07 PM
10/22/14 02:07 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
In car
Re: 5.7 Turbo in a A-body [Re: KRYPTONITE] #1688944
10/22/14 02:08 PM
10/22/14 02:08 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Ditch them and make your own. Those lines and that block off plate are way more of a headache than just ditching the spool mount trust me. Better yet, just swap K members to a non spool K.
Re: 5.7 Turbo in a A-body [Re: dizuster] #1688945
10/22/14 02:09 PM
10/22/14 02:09 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Hemi in Car
Re: 5.7 Turbo in a A-body [Re: KRYPTONITE] #1688946
10/22/14 02:17 PM
10/22/14 02:17 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Great post. I've been kicking around the idea of this swap and suspected it would be as bad as what you've run into. Unfortunately it looks like I'll have to just run an LS engine if I want a turbo in my Demon to avoid the headaches. It's a damn shame the Gen 3 hemi is so wide. I'd turbo the Gen 2 hemi in my car now if I could make it all fit. I'm already using a GM trans and Ford rear so my cars already a mutt.
Re: 5.7 Turbo in a A-body [Re: blowndart] #1688947
10/22/14 02:27 PM
10/22/14 02:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why don't you just turbo a Magnum? I mean how much power do you want? Boost makes stupid power no matter the block.
Re: 5.7 Turbo in a A-body [Re: dizuster] #1688948
10/22/14 02:39 PM
10/22/14 02:39 PM
South Carolina
K
K
South Carolina
Hemi in Car
Anymore pics what mount and manifolds?
Re: 5.7 Turbo in a A-body [Re: KRYPTONITE] #1688949
10/22/14 02:46 PM
10/22/14 02:46 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I'll have to look when I get home to see if I took any other pictures. But I was 100% confident setting it in there that it would work just as easily as the small block did. Like I said the manifold outlet locations were almost exactly in the same spot. I even held my hotside up to them to confirm.
Manifolds were off a '05~'07 magnum if I remember correctly. PM me and I'll try to get the casting number off them to verify.
Re: 5.7 Turbo in a A-body [Re: Mr.Yuck] #1688950
10/22/14 03:04 PM
10/22/14 03:04 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
LS is lighter w/high flowing factory heads and many will argue capable of much more abuse. There are many running 800+ HP with pretty much stock, high-mileage long blocks.
Re: 5.7 Turbo in a A-body [Re: blowndart] #1688951
10/22/14 03:14 PM
10/22/14 03:14 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: 5.7 Turbo in a A-body [Re: dizuster] #1688952
10/22/14 03:17 PM
10/22/14 03:17 PM
South Carolina
K
K
South Carolina
what mounts did you use?
Re: 5.7 Turbo in a A-body [Re: blowndart] #1688953
10/22/14 03:23 PM
10/22/14 03:23 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
No doubt about that...and the same could be said with the LS vs. Gen 3 comparison too. But to Yuck's point... how much power do you need? If you're looking for sub 700hp, just about anything will work with a turbo.
Re: 5.7 Turbo in a A-body [Re: KRYPTONITE] #1688954
10/22/14 03:29 PM
10/22/14 03:29 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Here are my mounts that adapt a non spool /6 K member. This could be configured different for more manifold room too. I can run the oil filter in stock location with this setup. Point is there are other ways to mount these things than spool swap mounts that IMO take up way to much realistate.
Re: 5.7 Turbo in a A-body [Re: 72Swinger] #1688955
10/22/14 03:43 PM
10/22/14 03:43 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
ok fella's i have a running driving N/A hemi in my 68 barracuda. i am looking to put a turbo on it this winter... so this post is awesome..i have a hemi denny tubular k frame so my set up is a little different. but i was looking at these. http://www.ebay.com/itm/Jeep-Grand-Chero...b3a&vxp=mtr
i have tti now. i think a 180 bend out the rear to get the exhaust up front...just spitballing here
Re: 5.7 Turbo in a A-body [Re: 72Swinger] #1688956
10/22/14 03:43 PM
10/22/14 03:43 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Im with you on this. I would build my own engine mounts if it was me without a doubt
Page 2 of 3 1 2 3
