Pinion snubber with super stock springs... Yes/ No? #1688598
10/21/14 03:21 PM
10/21/14 03:21 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
I'm getting close to completing my '70 Cuda, Gen II Hemi, 4-speed, 8.75 rear. I have Super Stock springs in back and seem to remember some differing opinions on whether or not to run a pinion snubber. What do you guys recommend?
It's a street car but I'll probably run drag radials. I have a forged yoke (7290) from Cass and the stock snubber bracket darn near touches it; like 1/16" clearance.
Re: Pinion snubber with super stock springs... Yes/ No? [Re: WarEagle1] #1688599
10/21/14 03:38 PM
10/21/14 03:38 PM
IF the SS springs work correctly the rear should lift up more than the pinion gear will twist up,the snubber will never touch the floor Take it off, it is extra weight I've tested the snubbers on many drag cars, they don't work with good springs
Re: Pinion snubber with super stock springs... Yes/ No? [Re: Cab_Burge] #1688600
10/21/14 03:40 PM
10/21/14 03:40 PM
an8sec70cuda Offline
When I ran SS springs, the car was quicker w/o the snubber. Back to back test at the track. This was on a mid 11 sec street/strip car.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pinion snubber with super stock springs... Yes/ No? [Re: an8sec70cuda] #1688601
10/21/14 04:21 PM
10/21/14 04:21 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
If you drive the car on the street it will annoy the crap out of you!
Re: Pinion snubber with super stock springs... Yes/ No? [Re: GY3] #1688602
10/21/14 04:31 PM
10/21/14 04:31 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
x2
...FAFO...
Re: Pinion snubber with super stock springs... Yes/ No? [Re: skicker] #1688603
10/21/14 06:25 PM
10/21/14 06:25 PM
Alabama
W
W
Alabama
So, will I be annoyed with or without the snubber? Not sure I understand. Please tell.
Re: Pinion snubber with super stock springs... Yes/ No? [Re: WarEagle1] #1688604
10/21/14 06:28 PM
10/21/14 06:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
If you run the aftermarket snubber on the street it will bump the floorpan. Even in the lowest setting..
Re: Pinion snubber with super stock springs... Yes/ No? [Re: GY3] #1688605
10/21/14 06:30 PM
10/21/14 06:30 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
ESPECIALLY if the car is lowered my challenger actually pivots on it, had to remove it
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Pinion snubber with super stock springs... Yes/ No? [Re: azmopar] #1688606
10/21/14 08:01 PM
10/21/14 08:01 PM
dogdays Offline
dogdays  Offline
Just say NO to pinion snubbers.
R.
Re: Pinion snubber with super stock springs... Yes/ No? [Re: dogdays] #1688607
10/21/14 08:13 PM
10/21/14 08:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
R.
Like what was said above, with SS springs, which have a shorter front segment to control spring windup on the launch, you shouldn't need the pinion snubber bandaid anymore. Plus you get to save weight, never forget about weight.
Re: Pinion snubber with super stock springs... Yes/ No? [Re: dogdays] #1688608
10/21/14 08:55 PM
10/21/14 08:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
R.
Just get some decent shocks and leave the snubber off
I run SS springs and Rancho adjustable shocks set on 8 at the track and 2 on the street
Gus
64 Plymouth Savoy
Dana 60
Re: Pinion snubber with super stock springs... Yes/ No? [Re: fourgearsavoy] #1688609
10/23/14 12:21 AM
10/23/14 12:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with everyone as I run SS springs and the car was no faster with the snubber on it so I took it off and dont use it. And I drive on the street alot and dont have to worry about it hitting the floor sometimes. Ron
Re: Pinion snubber with super stock springs... Yes/ No? [Re: 383man] #1688610
10/23/14 12:29 AM
10/23/14 12:29 AM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
This brings up a question as I have a adjustable snubber and super stock springs on my Challenger. If I take the adjustable snubbber off, should I reinstall a stock snubber or none at all?
Re: Pinion snubber with super stock springs... Yes/ No? [Re: Hemi_Jack] #1688611
10/23/14 04:07 AM
10/23/14 04:07 AM
or none at all?
None at all
Re: Pinion snubber with super stock springs... Yes/ No? [Re: Cab_Burge] #1688612
10/23/14 11:37 AM
10/23/14 11:37 AM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
As stated the SS springs have the shorter front segment that controls pinion wrap/roll. This creates less leverage. The longer front segment stock style creates more pinion leverage there fore a snubber can be a way to control this effect. Now considering the pinion adjustment. You are trying to align the pinion to the drive shaft under load. The snubber can help with this as it will control over wrap or positive pinion wrap over 0%. The car on the ground should have about 3% to 5% negative angle (pointing down). This will be dictated by HP and Torque the car generates. This can be achieved with tapered shims. Another consideration is the tire contact patch when you launch the car. The more pinion travel you have the more initial tire contact patch you create. This helps eliminate tire spin. Suspension tuning can be an art and is very unique to each car. This can be fun when you are looking for every hundredth of a second you can find.
Good luck
