Re: Pinion snubber with super stock springs... Yes/ No?
[Re: WarEagle1]
#1688599
10/21/14 03:38 PM
10/21/14 03:38 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
IF the SS springs work correctly the rear should lift up more than the pinion gear will twist up,the snubber will never touch the floor Take it off, it is extra weight I've tested the snubbers on many drag cars, they don't work with good springs
[Re: Cab_Burge]
#1688600
10/21/14 03:40 PM
10/21/14 03:40 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
When I ran SS springs, the car was quicker w/o the snubber. Back to back test at the track. This was on a mid 11 sec street/strip car.
[Re: dogdays]
#1688607
10/21/14 08:13 PM
10/21/14 08:13 PM
Challenger 1
Cincinnati, Ohio
Just say NO to pinion snubbers.
R.
Like what was said above, with SS springs, which have a shorter front segment to control spring windup on the launch, you shouldn't need the pinion snubber bandaid anymore. Plus you get to save weight, never forget about weight.
