Ever heard of a Bridgeway crank? #1688264
10/20/14 03:52 PM
10/20/14 03:52 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I purchased a forged crank from Ohio about 2 years ago... However, I'm told by my engine builder that if you research the numbers on the crank, it comes back as being manufactured by Bridgeway...
So I was just wondering if anyone has heard of them before..
http://www.bwcrank.com/about.php?nid=18
Re: Ever heard of a Bridgeway crank? [Re: Jeepmon] #1688265
10/20/14 03:56 PM
10/20/14 03:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
One of the many companies offering Chinese forgings these days. SEMA is over run with these booths at the show anymore. Would say a good 50% of the booths are from companies like Bridgeway.
From what I have seen Ohio is simply an importer of Chinese forgings. Guess this goes to bolster this argument further.
Re: Ever heard of a Bridgeway crank? [Re: Jeepmon] #1688266
10/20/14 04:31 PM
10/20/14 04:31 PM
When I bought my first batch (2001 or so) of stroker cranks from Ohio Crankshafts they told me that all thier cranks where made in the U.S.A. by Ohio Forge Maybe they have switch to Chinese cores since then
Re: Ever heard of a Bridgeway crank? [Re: Cab_Burge] #1688267
10/20/14 06:40 PM
10/20/14 06:40 PM
dogdays Offline
dogdays  Offline
Hey, I was wondering where to get a stroker crank for my BMW!
R.
Re: Ever heard of a Bridgeway crank? [Re: dogdays] #1688268
10/21/14 02:19 AM
10/21/14 02:19 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks you guys... I was kinda afraid that the OHIO cranks were made in China..
Re: Ever heard of a Bridgeway crank? [Re: Jeepmon] #1688269
10/21/14 02:12 PM
10/21/14 02:12 PM
dogdays Offline
dogdays  Offline
There's that word again. Most of the problems associated with Chinese cranks come down to the finish machining. I think that's where to put the emphasis on whether a crank is good or not.
R.
Re: Ever heard of a Bridgeway crank? [Re: dogdays] #1688270
10/21/14 02:30 PM
10/21/14 02:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
R.
I thaught I heard their refineries aren`t as good on quality controll as ours so from the gate they can be junk let alone final finish.
Re: Ever heard of a Bridgeway crank? [Re: Thumperdart] #1688271
10/21/14 02:49 PM
10/21/14 02:49 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Really nothing wrong with Chinese steel. The problem lies in what happens to the forging AFTER it is forged. Several cranks, while made in China are actually 100% machined and heat treated here in the states, The Callies K-1 line comes to mind. That is a BETTER crank than one machined in China and the price will reflect that. So bottom line, ALL China cranks are NOT the same
Monte
Re: Ever heard of a Bridgeway crank? [Re: Monte_Smith] #1688272
10/21/14 02:52 PM
10/21/14 02:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I was not implying it was good bad indifferent as far as the crank goes. Simply answering the question asked. There are ALOT of Chinese made cranks out there working just fine. As Monte pointed out pricing is way less than cranks made here in the US or machined here in the US.
Re: Ever heard of a Bridgeway crank? [Re: Al_Alguire] #1688273
10/21/14 04:33 PM
10/21/14 04:33 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I heard their refineries aren`t as good on quality control as ours
A rumor propagated by unemployed north american workers who, over time, became unproductive, non-caring and over-paid. All in the hope of bringing production back home. Unfortunately China has learned from north america's mistakes and unless there is an embargo of sorts, production of virtually everything will stay and continue to move there. They are also smart enough to see the value of investing in modern equipment and processes which help keep the costs down. And make no mistake about quality, they can make anything as good as anyone else. If you perceive a "quality" problem, the specification was the issue.
Many years ago in a "quality" course there was a story of an auto manufacturer contracting a Japanese company to make parts. The company said they would allow for 10% defects. The Japanese asked if they wanted the defects packed separately. The point being that they would MAKE 10% defective since that was being called for but "zero defects" was their standard.
The bottom line is this: if you get a poor quality Chinese item its because someone ordered it that way.
Re: Ever heard of a Bridgeway crank? [Re: Stanton] #1688274
10/22/14 01:57 AM
10/22/14 01:57 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
when it comes to finishing chinese cranks,their idea of runout is when the cat escapes the butcher block...nuff said.....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Ever heard of a Bridgeway crank? [Re: Jeepmon] #1688275
10/22/14 11:47 AM
10/22/14 11:47 AM
New York
polyspheric Offline
polyspheric  Offline
New York
In China, official corruption is not merely widespread, it's mandatory. No union, no OSHA, no SAE, no official standards, you can sue a manufacturer but the court has already decided in their favor.
Chinese steel foundries will "certify" steel with garbage (slag, dirt, sand) in it that nothing will remove and heat treatment won't fix.
The good news: not all of them are bad, they don't do it on purpose - it's just cheaper to make. Easy safety measure: if you order 10, and destroy 1 (X-ray, cut a journal in half for microscopy) and it's good, the other 9 are probably good.
Boffin Emeritus
Re: Ever heard of a Bridgeway crank? [Re: polyspheric] #1688276
10/22/14 12:42 PM
10/22/14 12:42 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Wow.. I didnt expect this thread would become a China bashing thread...
When I went crank shopping about 2 years ago, I could have sworn Ohio Cranks had a "Made in the USA" notice posted.. In addition to that, I've spoken with Cab and (at that time) he confirmed the information he had was that they were made in USA also..
Then there was a few reports that the steel came from China and the inspection and machining was done here... Regardless, I never once heard bad things about Ohio Cranks... So I bought one and outside of a minor difference at the snout, the crank seemed to have checked out with my machine shop at the time..
Since then... today actually, my new engine builder said I have a step in the journals that would not polish out.. so he will have to turn it... When doing research on the castng number, he discovered it was made by Bridgeway, which prompted me to ask if anyone has ever heard of them...
Here's to hoping I have a good solid crank and it wont melt like butter during the machine work...
Re: Ever heard of a Bridgeway crank? [Re: Jeepmon] #1688277
10/22/14 01:45 PM
10/22/14 01:45 PM
dogdays Offline
dogdays  Offline
Which is why I said "there's that word again". You only have to mention the name of that particular country and the haters will come out.
My point about the finish machine work was that I have read or heard very few material-related failures of the 4340 Chinese forgings, the most-often criticism was the accuracy of things from the machining process like tapered journals or journals not indexed properly. Many of these opinions came from Dan(RIP) at Performance Only back when he was posting using a different handle.
What the haters won't admit is that before the start of the Chinese forgings, there were precious few ways to make a stroker Mopar that didn't involve buying $1100 rods and cranks(that's in 1995 dollars). So basically the whole era of cheap Mopar strokers (as well as most other brands)came straight outta' China.
But haters gotta hate.
Now to the question of made in the USA. I have seen forged 6" chevy connecting rod blanks on the 'bay for $2 each. So if I buy a box of them and invest in the machinery and skilled labor to turn them into finished rods that cost me a total of $25, where was most of the money spent? By some definitions, that rod is made in the USA. Happens all the time in industry. Guys in Wisconsin assembling foreign parts into valves that have "Made in USA" printed onto their nameplates.
End of rant.
R.
Re: Ever heard of a Bridgeway crank? [Re: dogdays] #1688278
10/24/14 12:17 AM
10/24/14 12:17 AM
dakotawilly Offline
dakotawilly  Offline
todays order,1 egg foo young,2 egg rolls,1 order fried rice,and 1 4.25 stroke crankshaft,spicy please,delivered
Re: Ever heard of a Bridgeway crank? [Re: dakotawilly] #1688279
10/24/14 09:00 AM
10/24/14 09:00 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That's " Preeze " to you , Jack.
