AJE Suspension #1688132
10/20/14 08:29 AM
10/20/14 08:29 AM
South Carolina
K
KRYPTONITE Offline OP
K
South Carolina
Has anyone ran or used AJE Suspension? anyone info. on how there product is? and also Tech. susport?
Re: AJE Suspension [Re: KRYPTONITE] #1688133
10/20/14 09:24 AM
10/20/14 09:24 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Very bad reviews if you do a search on here. Gets very expensive once you buy everything you need. There are much better options.
Re: AJE Suspension [Re: 496 A-body] #1688134
10/20/14 09:41 AM
10/20/14 09:41 AM
South Carolina
K
K
South Carolina
Thanks man, did a search. glad I read it.
Re: AJE Suspension [Re: KRYPTONITE] #1688135
10/20/14 09:47 AM
10/20/14 09:47 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
If I were in the market for aftermarket bolt in front suspension I would go with Bob's pro fab. I've talked to him when doing a coilover conversion on my stock k member/lower control arm set-up and he was very helpful. His k member looks awesome and has lots of positive reviews. But I will probably go with struts if I decide to upgrade from what I currently have.
Re: AJE Suspension [Re: 496 A-body] #1688136
10/20/14 09:52 AM
10/20/14 09:52 AM
South Carolina
K
K
South Carolina
Yes sir. I have looked at his work alot. Just saw the AJE front suspension and figured I would see if anyone had info. on it. I guess I will be in contact with Bob.
Thanks again for the help
