battery going dead #1688027
10/19/14 08:50 PM
10/19/14 08:50 PM
ohio
slomoshun Offline OP
ohio
i have a new battery about 6 months old and after it sits for about 2 weeks it goes dead. the master switch is turned off and the only thing hooked up is the volt gauge and alternator (single wire alternator). I recharged the battery and unhooked the alt.and it is still at full charge after 2 days. my question is could something have happened to alt. causing it to drain the battery. I have raced very little this year but when at track alt. is charging
Re: battery going dead [Re: slomoshun] #1688028
10/19/14 09:02 PM
10/19/14 09:02 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
Disconnect alternator for a few days & see if problem goes away, if it does, then check for leaky diodes in the alternator.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: battery going dead [Re: 1KoolBee] #1688029
10/19/14 10:22 PM
10/19/14 10:22 PM
Suffolk,VA
dragracedr Online content
dragracedr  Online Content
Suffolk,VA
I agree. I had a Suzuki Samurai 1-wire conversion alternator wired straight to the battery. Had to disconnect when the racecar sat due to diode problems causing slow draw.
Re: battery going dead [Re: slomoshun] #1688030
10/20/14 12:17 AM
10/20/14 12:17 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
A full-time wired volt guage draws current..
Disconnect the guage and see if it makes a difference..
Just my $0.02..
Re: battery going dead [Re: Sinitro] #1688031
10/20/14 12:34 AM
10/20/14 12:34 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
I have my alt wired to the battery side of the master switch and my volt gauge wire to a 12 volt ignition source.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
