Manual Master Cylinder bore size - Disc/Drum #1687694
10/19/14 11:48 AM
10/19/14 11:48 AM
Oklahoma
Mopar72Man Offline OP
Oklahoma
I am currently running a 1.125" bore 2-bolt master cylinder with front 11-3/4" brakes and rear 10" drums. I pretty much hate it, I've had it on there for quite a while and am not too happy with the effort required. I'd like to go down to a 1.032" master and an aftermarket proportioning valve.
I would like to run rear discs in the near future and want to make sure I won't regret making the swap.
What master are you running and is it with disc/disc or disc/drum?
Thanks!
Which bore master cylinder?
single choice
Votes accepted starting: 10/19/14 09:48 AM
Which brake type combination
single choice
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: Manual Master Cylinder bore size - Disc/Drum [Re: Mopar72Man] #1687695
10/19/14 12:21 PM
10/19/14 12:21 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I have the same setup you do in a Duster with a 15/16" master cylinder from Dr. Diff. Had a 1 1/32 before and it's a lot better. That's what I would suggest.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Manual Master Cylinder bore size - Disc/Drum [Re: goldduster318] #1687696
10/19/14 12:36 PM
10/19/14 12:36 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I was looking for the correct 1" bore m/c for my big block A body. The particular unit is pretty much unobtainable. Got with the Ramman. He set me up with a unit that had a 11/16" bore which is pretty close. I've since found the correct numbers correct unit which he's restoring so I won't be needing the one he setup for me.
Re: Manual Master Cylinder bore size - Disc/Drum [Re: Mopar72Man] #1687697
10/19/14 12:54 PM
10/19/14 12:54 PM
upper So. CA
N
ntsqd Offline
ntsqd  Offline
N
upper So. CA
What calipers do you have? If OE, what is their piston diameter?
I'm using wilwood dynapro's (way stiffer than dynalites of any flavor) with a late model Mopar 1-1/16 M/C and I find the pedal effort to be just about right. This is in a '65 A body, which sets up the next question.
What is the ratio of your pedal?
This is going somewhere, so please bear with me.
I used to swerve around my hallucinations, now I drive right thru them.
Re: Manual Master Cylinder bore size - Disc/Drum [Re: Mopar72Man] #1687698
10/19/14 05:39 PM
10/19/14 05:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you have the room for the additional pedal travel, go with a 15/16".
Re: Manual Master Cylinder bore size - Disc/Drum [Re: John_Kunkel] #1687699
10/19/14 06:45 PM
10/19/14 06:45 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
15/16" here.
Mopar to the bone!!!
Re: Manual Master Cylinder bore size - Disc/Drum [Re: 72Swinger] #1687700
10/19/14 08:46 PM
10/19/14 08:46 PM
Oklahoma
Oklahoma
Thanks for the input. Does anyone have a part number for the 15/16" bore? I haven't been able to find that in the 2-bolt flavor.
Also, do all of the aluminum 2-bolt masters have a provision for the manual pushrod grommet?
Re: Manual Master Cylinder bore size - Disc/Drum [Re: Mopar72Man] #1687701
10/19/14 09:03 PM
10/19/14 09:03 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Re: Manual Master Cylinder bore size - Disc/Drum [Re: 72Swinger] #1687702
10/21/14 12:49 AM
10/21/14 12:49 AM
upper So. CA
N
ntsqd Offline
ntsqd  Offline
N
upper So. CA
Without knowing the caliper piston area and pedal ratio it is impossible to choose the m/c size. Or suggest one.
Re: Manual Master Cylinder bore size - Disc/Drum [Re: 72Swinger] #1687703
10/22/14 09:18 AM
10/22/14 09:18 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I also use the Dr. Diff 15/16" MC with "manual" disc (OE 11-3/4") up front and 11" OE drums in the rear.
Re: Manual Master Cylinder bore size - Disc/Drum [Re: YO7_A66] #1687704
11/04/14 08:08 PM
11/04/14 08:08 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Disk/Disk
7/8 piston
6-1 pedal
Re: Manual Master Cylinder bore size - Disc/Drum [Re: Lefty] #1687705
12/11/14 11:18 AM
12/11/14 11:18 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
Disk/Disk
7/8 piston
6-1 pedal
A co-worker was telling me he has a `95 (?) Dakota 7/8" master in his **** with 4 wheel disc w/o a proportioning valve. Says it stop fine (90% drag car, 10% street) Anyone have experience with this unit?
Not to hi-jack, but I'm planning on adding rear disc over the winter. I already have an aluminum Mopar M/C similar to the one advertised by Dr. Diff. Is there any way to tell bore size without pulling it all apart? I installed this M/C 10 yrs. ago and honestly don't remember the bore size. I got it from a well know supplier and it was advertised for a Diplomat.
Car is a `68 A body, stock 4 piston front disc, will be adding a Right Stuff rear conversion, which uses Ford calipers.
Thanks!
`68 Barracuda 340-S
Re: Manual Master Cylinder bore size - Disc/Drum [Re: Mopar72Man] #1687706
12/13/14 12:28 AM
12/13/14 12:28 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It's time for the brake math spreadsheet.
http://3gduster.com/brakes.html
I've got an updated version available should anyone want it.
- Stu Harmon
Re: Manual Master Cylinder bore size - Disc/Drum [Re: feets] #1687707
12/13/14 12:47 AM
12/13/14 12:47 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Those will do for some pretty basic numbers, adding relative weight transfer and rate of deceleration will help provide some input on how those numbers relate to the world. Our FSAE spreadsheets were in G of deceleration with force varying force input that could be plotted.
Don't forget units on your spreadsheet Feets. You mention pounds as one of your inputs, the rest should be Imperial/US or some can end up with a wonky pounds-MM and not know it.
I wasn't the guy in charge of braking/pedal box however, so I'm not the guru in this field by any means.
[spreadsheet goes up to 2G, but I just cut the screenshot short]
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Manual Master Cylinder bore size - Disc/Drum [Re: feets] #1687708
12/13/14 05:24 AM
12/13/14 05:24 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
While your reply reminds me of the old saying "I asked what time is it, not how to build a watch", your spreadsheet IS the absolute definitive answer to what was asked. Thank you.
`68 Barracuda 340-S
Re: Manual Master Cylinder bore size - Disc/Drum [Re: GoodysGotaCuda] #1687709
12/13/14 10:48 PM
12/13/14 10:48 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Goody, it is possible to over engineer things. I sometimes have a hard time knowing when to stop "making it better."
What I posted is a very basic spreadsheet that I cobbled together late one night. As I stated above, I have an updated version available that does have units of measure listed. However, I do not have admin access to that link so I can't change it.
The spreadsheet won't win any Formula 1 races (especially with friction as 1) but it'll be more than enough for a car on the street.
- Stu Harmon
