Re: Manual Master Cylinder bore size - Disc/Drum
[Re: Mopar72Man]
#1687695
10/19/14 12:21 PM
10/19/14 12:21 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have the same setup you do in a Duster with a 15/16" master cylinder from Dr. Diff. Had a 1 1/32 before and it's a lot better. That's what I would suggest.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Mopar72Man]
#1687697
10/19/14 12:54 PM
10/19/14 12:54 PM
Posts: 40 upper So. CA
ntsqd
upper So. CA
What calipers do you have? If OE, what is their piston diameter?
I'm using wilwood dynapro's (way stiffer than dynalites of any flavor) with a late model Mopar 1-1/16 M/C and I find the pedal effort to be just about right. This is in a '65 A body, which sets up the next question.
What is the ratio of your pedal?
This is going somewhere, so please bear with me.
I used to swerve around my hallucinations, now I drive right thru them.
[Re: Mopar72Man]
#1687698
10/19/14 05:39 PM
10/19/14 05:39 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you have the room for the additional pedal travel, go with a 15/16".
[Re: 72Swinger]
#1687702
10/21/14 12:49 AM
10/21/14 12:49 AM
ntsqd
upper So. CA
Without knowing the caliper piston area and pedal ratio it is impossible to choose the m/c size. Or suggest one.
[Re: 72Swinger]
#1687703
10/22/14 09:18 AM
10/22/14 09:18 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I also use the Dr. Diff 15/16" MC with "manual" disc (OE 11-3/4") up front and 11" OE drums in the rear.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Mopar72Man]
#1687706
12/13/14 12:28 AM
12/13/14 12:28 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It's time for the brake math spreadsheet. http://3gduster.com/brakes.htmlI've got an updated version available should anyone want it.
[Re: feets]
#1687707
12/13/14 12:47 AM
12/13/14 12:47 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Those will do for some pretty basic numbers, adding relative weight transfer and rate of deceleration will help provide some input on how those numbers relate to the world. Our FSAE spreadsheets were in G of deceleration with force varying force input that could be plotted.
Don't forget units on your spreadsheet Feets. You mention pounds as one of your inputs, the rest should be Imperial/US or some can end up with a wonky pounds-MM and not know it.
I wasn't the guy in charge of braking/pedal box however, so I'm not the guru in this field by any means.
[spreadsheet goes up to 2G, but I just cut the screenshot short]
[Re: GoodysGotaCuda]
#1687709
12/13/14 10:48 PM
12/13/14 10:48 PM
feets
Senior Management
Senior Management
Irving, TX
Goody, it is possible to over engineer things. I sometimes have a hard time knowing when to stop "making it better."
What I posted is a very basic spreadsheet that I cobbled together late one night. As I stated above, I have an updated version available that does have units of measure listed. However, I do not have admin access to that link so I can't change it.
The spreadsheet won't win any Formula 1 races (especially with friction as 1) but it'll be more than enough for a car on the street.
