Re: 1968 440 block with a blank VIN pad ??
[Re: Kern Dog]
#1687503
10/18/14 10:38 PM
10/18/14 10:38 PM
Posts: 75,300 A gulag near you.
JohnRR
A gulag near you.
So I guess I need a mirror to see it unless I pull the engine. Great!
What difference does it make if you can see the VIN ?? It's not the original engine in the car obviously.
You don't have to pull the engine, or use a mirror, spray the area down good with brake parts cleaner, or hit it with a pressure washer, lay over the top of the engine while shinning a light down there and see what you can see ...
As far as warranty replacement goes, it seems to me that there are more warranty replacement engines out there than Chrysler actually changed under warranty ...
[Re: JohnRR]
#1687505
10/19/14 12:03 AM
10/19/14 12:03 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
"What difference does it make if you can see the VIN ?? It's not the original engine in the car obviously."
No need to be rude. My point was that a VIN stamping might shed light onto the original car the engine may have been installed in. There have been stories where people spend years looking for their original engines.
[Re: Cab_Burge]
#1687510
10/19/14 01:54 AM
10/19/14 01:54 AM
JohnRR
A gulag near you.
It seems to me that all the 1968 wedge motors had the VIN stamp on the top of the motor like shown and stamp on one of the ears supporting the outside tranny bolts by the starter or the other side Either way a warrenty motor won't have a VIN number stamp on it, my 1970 V code Charger had a warrenty motor in it with a casting date of 4-19-1970 and the car had a schedule assembly date in late Oct 1969
Not all 68 motors were stamped back there, I would expect an HP motor to be stamped though. I pulled a 68 383 2bbl from it's original body , I still have the block, no VIN stamped on it.
A warranty motor shouldn't be stamped like a Production line motor , unless it was a complete motor pulled out of a line of pallets headed to an assembly plant. A motor would have to be much pretty blown up to get a full engine replaced.
[Re: Kern Dog]
#1687511
10/19/14 01:57 AM
10/19/14 01:57 AM
JohnRR
A gulag near you.
It seemed to be acceptable for Hill ??
There are no records for 68 , best you will get it a platform or model line it COULD have been in depending on the build plant, but there are a few members that seem to be able to come up wit ha model fairly often ???
68 440 HP ??? GTX, Coronet R/T, Charger R/T or a C barge that was available with an HP 440 ...
[Re: JohnRR]
#1687512
10/19/14 02:01 AM
10/19/14 02:01 AM
Posts: 706 USA
rftroy
USA
I used to own a '68 383 Dart. The block had no VIN stamping. At the time I knew a guy with a 383 68 Barracuda; his engine also had no VIN stamping. I have a 383 block in my garage right now, which was pulled from a 68 383 Dart, and is slated for my 68 383 convertible. It also has no VIN stamping.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: Rhinodart]
#1687514
10/19/14 02:08 AM
10/19/14 02:08 AM
JohnRR
A gulag near you.
I am rebuilding a 383 out of a 68 Dart GTS right now and it has the VIN stamped on it like the picture shown above.
[Re: Rhinodart]
#1687515
10/19/14 02:11 AM
10/19/14 02:11 AM
Posts: 17,551 Las Vegas, NV
6bblgt
Las Vegas, NV
1968 Model year: engines & transmissions 340s VIN stamp HEMI VIN stamp 383 4bbl VIN stamp 440HP VIN stamp 440 NO stamp 383 2bbl NO stamp 318 NO stamp 273 NO stamp /6 NO stamp
[Re: JohnRR]
#1687516
10/19/14 02:12 AM
10/19/14 02:12 AM
Posts: 43,897 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Here is a 440 out of a Mr. Norms 68 Dart GSS with the VIN on the bellhousing rail too... (if only I could learn how to use a camera)
JB Rhinehart, Realist
A-Body's RULE!
