5.2 in 98 Grand Cherokee #1687300
10/18/14 12:38 PM
10/18/14 12:38 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
I just swapped my beater car for a 98 Jeep Grand Cherokee with the 5.2 and quadratrac 4wd.
Who makes headers for the GC?I see them listed for Dakotas all over the place.Do these fit or are there Jeep specific ones?
I plan to do some other basic mods such as exhaust/air intake,and maybe a computer upgrade of some sort.Any other "best band for the buck" mods as this is my first "magnum" motor?
Re: 5.2 in 98 Grand Cherokee [Re: gch] #1687301
10/19/14 03:51 AM
10/19/14 03:51 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
doug thorley makes a tri-y header for the 5.2 gc, but they are sort of "pricey".
Re: 5.2 in 98 Grand Cherokee [Re: Golden-Arm] #1687302
10/19/14 09:55 AM
10/19/14 09:55 AM
Central NC
gch Offline OP
gch  Offline OP
Central NC
I saw them listed and they are $$$.Does anyone know if the dakota/durango headers will fit?
Re: 5.2 in 98 Grand Cherokee [Re: gch] #1687303
10/19/14 11:52 AM
10/19/14 11:52 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
maybe 92 dakota exhaust manifolds,best smallblock manifolds made
Re: 5.2 in 98 Grand Cherokee [Re: gch] #1687304
10/20/14 01:22 PM
10/20/14 01:22 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Not likely,V-8 GC's were center dump on one side, whatever you do get the exh away from the oil pan. Those things cooked the oil and many engines paid the price.Full syn oil is mandatory.
Leave the gun.......take the Cannoli's....Mike
Re: 5.2 in 98 Grand Cherokee [Re: mike s] #1687305
10/20/14 06:58 PM
10/20/14 06:58 PM
dogdays Offline
dogdays  Offline
Jeep engine compartments are quite a bit different, they had their own manifolds. I doubt you'd have luck with anything not specifically built for the Jeep.
The first modification you should make is to replace the gasket and plate under the intake.
R.
