Re: pinging at higher RPMs and faster speeds
[Re: moparmikethree]
#1687248
10/18/14 12:45 PM
10/18/14 12:45 PM
RapidRobert
At what RPM/in hg does it start to ping? What RPM do the springs (slots) max out at? when it starts to ping are you on the cruise or power circuit? (what PV/metering rod springs?) Depending on your DCR you may need more octane & if you dont want to upgrade then yes it'll have to be detuned (assuming no system is way out of whack here that NEEDS to be changed). What is your cranking compression & what octane? You might turn the can 2 or 3 turns CCW with the 3/32" allen wrench & retry. Until you solve it stay in pinging mode as little as possible as it is extremely damaging to the eng.
#1687249
10/18/14 05:06 PM
10/18/14 05:06 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Sounds like a lean miss up all jets a couple sizes and try that. What Carb.
