compression #1687233
10/18/14 08:17 AM
10/18/14 08:17 AM
budd12 Offline OP
budd12  Offline OP
If my 340 is 10 to 1 compression how much should the compression gage read?? 150# or 160#?? I had a 12 to 1 and it had about 180#
Re: compression [Re: budd12] #1687234
10/18/14 09:59 AM
10/18/14 09:59 AM
SE PA
Yellow Fever Offline
SE PA
Depends on the cam etc. I would just make sure they are all pretty even between them.
Re: compression [Re: Yellow Fever] #1687235
10/18/14 12:32 PM
10/18/14 12:32 PM
budd12 Offline OP
budd12  Offline OP
thanks for the reply, I just checked two cylinders and the were both 160, so I think all is well.
Re: compression [Re: budd12] #1687236
10/18/14 05:33 PM
10/18/14 05:33 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
How do you know all is well if you didn't check all eight cylinders?
Re: compression [Re: dirtybee] #1687237
10/18/14 06:08 PM
10/18/14 06:08 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Remove all the spark plugs - then check each cylinder with no plugs in the engine at all.
This way if you have a leak between two cylinders you wont get false reading.
A little more info would be helpful - why are you testing compression?
Re: compression [Re: dirtybee] #1687238
10/18/14 06:08 PM
10/18/14 06:08 PM
budd12 Offline OP
budd12  Offline OP
Its a fresh motor just changed the cam, and it was running sluggish, so I was concerned that the cam was in a tooth out (retarded) so if it was, the compression would be low, not sure how low, but for sure not 160#.Had the timing at 37deg. had to go up to 45deg for the motor to act rite, got lots of power at 45. I think my timing lite is toast.
"SHOULD HAVE DEGREED IT IN"
