Changing from 513s to 410s Dana #1686904
10/17/14 03:33 PM
10/17/14 03:33 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
If I swapped the 513 ring/pinion for 410s in my Dana, would I need any special parts or spacers? Thanks
Re: Changing from 513s to 410s Dana [Re: BH27G1B] #1686905
10/17/14 03:37 PM
10/17/14 03:37 PM
an8sec70cuda Offline
You'll need a 4.10 and numerically lower carrier/diff.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Changing from 513s to 410s Dana [Re: BH27G1B] #1686906
10/17/14 08:03 PM
10/17/14 08:03 PM
If your spool or posi unit has a ring gear spacer in it now you can PROBALLY reuse the old one by removing the spacer If not you will need a new series three carrier or spool to match the ring and pinion used
Re: Changing from 513s to 410s Dana [Re: BH27G1B] #1686907
10/17/14 08:08 PM
10/17/14 08:08 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
u can buy thick ring gear without changing centersection.same price do it all the time on jeeps just read the post u are going the other way so u need new carrier
Re: Changing from 513s to 410s Dana [Re: an8sec70cuda] #1686908
10/17/14 08:19 PM
10/17/14 08:19 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
That is where you begin
I have done a few of these and until recently, I never had a case spreader which is what the pros use. You may be able to reuse the press on carrier and pinion gear bearings if you can get them off the old ones, but I have always bought new.
The one thing I found to be invaluable is a set of set-up bearings. In the kit you get a selection of shims for the carrier and pinion gear and a set of honed bearings for a slip fit on the carrier. Insert the pinion gear in the case with a pressed on bearing (new or used). Start with the original shim pack on the pinion and add or subtract shims as needed. Assemble without the seal because you will be working up to the final setting. Bolt the new ring gear in place on the carrier (new bolts are a good idea) I start with the old shim pack on the carrier and adjust as necessary. This involves a LOT of trial and error. I am not an expert. Once you have established the proper pinion depth and backlash then you can press the new bearings on the carrier and pinion gear and assemble the rear. It is a lot easier to do this with the rear out of the car.
Or you can just take your ride to the local differential shop and pay the man
I have always had a lot more time than money and I am not afraid to get dirty.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Changing from 513s to 410s Dana [Re: Polarapete] #1686909
10/17/14 11:58 PM
10/17/14 11:58 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
They used to make a 4.10 set with a thin ring gear. In my last drag car, I went from 4.88 to 4.10. This was with a spool.
I hope they are still made because I need a set. I want to street drive my '67 Belvedere. Original gear was 4.88, I hope to change to 4.10 without having to buy a new carrier and axles. Why new axles? I doubt there are any new 23 spline 3 series carriers so I'd have to change to 35 spline carrier and axles.
Re: Changing from 513s to 410s Dana [Re: d-150] #1686910
10/18/14 01:03 AM
10/18/14 01:03 AM
If I'm remebering correctly the standard 4WD Jeeps use Dana 44 and Dana 27 and maybe one other Dana Corp. rear ends(Dana30?), not Dana 60, correct? If so I have not heard of any of the after market gear companys making thick and thin ring gear sets for Dana 60 I know that Dana/Spicer Corp. made different thickness ring and pinion gear sets for the Dana 70 and maybe the Dana 80, probally the same on the Dana 44 but not the Dana 60 that I'm aware of
Re: Changing from 513s to 410s Dana [Re: Cab_Burge] #1686911
10/18/14 01:26 AM
10/18/14 01:26 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Back in the day when i put the dana in my car it had a 3.54 gear with power lock. Went with 5.13 and did't want the spacer so i popped in the lathe milled off the bearing shoulder the needed amount, just added more shims on the other side. Check the cross pin for clearnce too. Could do the same to a spool whitch ever way it needs to go. If power- lock odds are its the right one.
Re: Changing from 513s to 410s Dana [Re: cudaman1969] #1686912
10/18/14 08:54 AM
10/18/14 08:54 AM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
What ring/pinion set could I use for a direct swap? 488s ? 456s ?
Re: Changing from 513s to 410s Dana [Re: Cab_Burge] #1686913
10/18/14 10:48 AM
10/18/14 10:48 AM
BDW Offline
BDW  Offline
What he said
When I picked up my Dana, it had 5.38s in it, but it had a spacer.
3.73s bolted right in. So check for a spacer before buying parts.
Re: Changing from 513s to 410s Dana [Re: BH27G1B] #1686914
10/18/14 08:45 PM
10/18/14 08:45 PM
fredericksburg,va
fredericksburg,va
Two groups 4.56 up and 4.10 down, not sure with the new 4.30. Just remembered we broke our 5.13, next day put a 4.10 on the same spool so it had room to use both. 5.13 to 4.56 you won't see much change, waste of time imo
Re: Changing from 513s to 410s Dana [Re: Cab_Burge] #1686915
10/18/14 10:25 PM
10/18/14 10:25 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
not being smart but they do make thick 60 sets also,but op is going the other way
Re: Changing from 513s to 410s Dana [Re: BH27G1B] #1686916
10/19/14 02:04 PM
10/19/14 02:04 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: Changing from 513s to 410s Dana [Re: GomangoCuda] #1686917
10/19/14 06:14 PM
10/19/14 06:14 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Found on Strange website http://www.strangeengineering.net/high-p.../gear-sets.html
Like I posted above, I knew they made them at one time when I went from 4.88 to 4.10.
Glad they still do as my car still has the factory 4.88.
Re: Changing from 513s to 410s Dana [Re: B5 Bee] #1686918
10/20/14 12:46 AM
10/20/14 12:46 AM
I have heard that the racing Pro series 4.10 gear sets, all sets, are the 4.56 and above ring gear types as far as what they fit onto. I've never seen or set up a set of them so it is all hearsay to me Dana didn't make them Richmond did My current drag car has a Dan 60 in it with Mark Williams 40 spline axles and it had a set of 5.86 pro gears in it on a Mark williams aluminum spool , I was told that it had a set of Pro 5.13 gears, not so I changed them last winter and got a education on Dana 60 gear sets and spools and posi, nobody makes a three series 40 spline spool so I ended up using a stock set of Dana Corp. 4.56 gears out of a old pick up rear end on a new Mosar 40 spline steel spool. If I could have bought a three sereis 40 spline spool I would have put a set of 4.10 in my car instead of the 4.56 I did buy a set of Richmond 4.30 for my Dana 60, they only fit the three series carriers and spool also
