Window Net examples??? #168672
12/16/08 07:38 PM
12/16/08 07:38 PM
HR3128 Offline OP
HR3128  Offline OP
Anybody have some pics of how you mounted your window net bottom bar? I bought a RJS kit. I got the top bar in place but I'm having trouble coming up with something for the bottom bar. It needs to be able to move so that climbing in and out of the car is as easy as possible. Thanks for your help.
Re: Window Net examples??? [Re: HR3128] #168673
12/16/08 08:13 PM
12/16/08 08:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 2 pieces of tubing 3/8" ID X maybe 5/8"OD X 3/4 long
welded to my bar( the angled one that goes up to
the main hoop). The 3/8 rod goes thru the net and
goes thru both pieces of the tubing with a jesus
clip at each end of the rod to hold it from sliding out, very
simple. I'll see if I can find a pic
Post deleted by Defbob [Re: HR3128] #168674
12/17/08 12:38 AM
12/17/08 12:38 AM
Re: Window Net examples??? #168675
12/17/08 12:45 AM
12/17/08 12:45 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
not the best pic but you get the idea. has 4 tabs welded on the main hoop, and a nut welded to the door bar to bolt the front brace to. normal seat buckle on the top to latch it
Re: Window Net examples??? [Re: prochargedhemi] #168676
12/17/08 06:59 PM
12/17/08 06:59 PM
HR3128 Offline OP
HR3128  Offline OP
Here's my problem. The net is not long enough to mount directly to the door cross bar. I had mounted the bottom window net bar to a bracket that was welded to the door cross bar but it made getting in & out a pain. So I'm trying to make up something so that the bottom net bar can be dropped or moved out of the way but the I am not having much luck on this. Any ideas? Thanks.
Re: Window Net examples??? [Re: HR3128] #168677
12/17/08 07:15 PM
12/17/08 07:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Roy, where do you live in Mich, you can go right
to RJS with your templete and they can make it.
Usually most of the guys drop the top of the net
and the bottom is on a fixed rod with clips, the
upper rod uses a seatbelt lock. You might want to
pick up the RJS installation kit also.
http://www.rjsracing.com/windownets.html
Re: Window Net examples??? [Re: MR_P_BODY] #168678
12/17/08 08:19 PM
12/17/08 08:19 PM
HR3128 Offline OP
HR3128  Offline OP
The template thing is what I should have done if I was smart but that's something I have never been accused of.
Mr.P, Chesterfield (I-94 & M-19), not to far from you. Thanks for the link. The RJS kit is what I bought. The top bar is installed close to the top rollcage bar. I had the bottom installed but did not like the way it turned out. I'll keep messing with it until it works.
Re: Window Net examples??? [Re: HR3128] #168679
12/17/08 08:25 PM
12/17/08 08:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made a templete of mine and ran it for a while
but I took in this spring and had them change it
when I re-newed it... pretty cheap ( I cant remember
the price). It might be easier and look nicer if
you get the right shape net
Re: Window Net examples??? [Re: MR_P_BODY] #168680
12/17/08 08:44 PM
12/17/08 08:44 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Or you can connect the bottom left corner with a cable, that is how the S&W Race Cars kit comes.
Re: Window Net examples??? [Re: Forest] #168681
12/17/08 09:29 PM
12/17/08 09:29 PM
HR3128 Offline OP
HR3128  Offline OP
Are the tech guys OK with the cable?
Re: Window Net examples??? [Re: HR3128] #168682
12/17/08 10:52 PM
12/17/08 10:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They dont even look at the net or mounting of it
Re: Window Net examples??? [Re: HR3128] #168683
12/17/08 11:19 PM
12/17/08 11:19 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
I did a custom net to match the angle of the rollcage side bar. It's solid on the bottom. The front of the net has the sewn in loops for the bar to run thru. It pivots on the bottom, clips on the top. I like pushing the net forward to clip into place, but some like to push up to clip it, both work.
Re: Window Net examples??? [Re: 4404dart] #168684
12/17/08 11:37 PM
12/17/08 11:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like yours better than mine, I have the same shape
net but mine has the bar top and bottom with my
upper bar pushing up into the lock. You lock is
more out of the way than mine
Re: Window Net examples??? [Re: MR_P_BODY] #168685
12/17/08 11:48 PM
12/17/08 11:48 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Mine
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Window Net examples??? [Re: MR_P_BODY] #168686
12/17/08 11:58 PM
12/17/08 11:58 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
Thanks, I appreciate that.
Re: Window Net examples??? [Re: 4404dart] #168687
12/24/08 12:13 AM
12/24/08 12:13 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I found a pic of mine mounted with a cable.
