Re: degreeing cams with advance ground in
[Re: mopar dave]
#1686722
10/17/14 03:30 PM
10/17/14 03:30 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Every cam I've degreed in recent years was 4° advanced when installed "on the pin". I've always assumed this was to compensate for chain stretch.
[Re: mopar dave]
#1686723
10/17/14 05:49 PM
10/17/14 05:49 PM
BradH
ok, how do I check it with the open/close specs on the card?
Google "how to degree a camshaft" and take your pick...
[Re: Thumperdart]
#1686730
10/17/14 09:53 PM
10/17/14 09:53 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
For the life of me i can't understand the reasoning for the cam manufactuers doing this. Just make it straight up. For a stock engine, dot to dot. Race cam degree it in like it should be. Maybe cam guys did this for the person who has no idea how to degree a cam in the first place but knows how to dot to dot. Reminds me of the time a dude brought me a 383 that wouldn't fall out a tree. Checked the cam and found a 8• retarded button on the cam pin and 4• retarded crank keyway. After i fixed it i told him not to touch the engine again, he said why...
Problem is dot 2 dot isn`t always where it should be.........
For a 318 2barrel it is or any dead stock engine for that matter
[Re: cudaman1969]
#1686732
10/17/14 10:19 PM
10/17/14 10:19 PM
Posts: 4,684 Wichita
GY3
Wichita
Any time you introduce aftermarket parts into the mix, you run the risk of parts not being machined or stamped correctly.
I always degree a cam even if its a stock rebuild!
Dot to dot does not cut it!
