might be a crazy question. #1686490
10/16/14 05:24 PM
10/16/14 05:24 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
I just picked up a 70 Challenger with a 360. Car does not want to run with a non vented gas cap. Take the cap off and it will crank and run fine. I have not tried driving it like this though. Does this make any since?
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: might be a crazy question. [Re: Boosted] #1686491
10/16/14 05:28 PM
10/16/14 05:28 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If there is no good vent for the fuel tank it will likely have that problem.
The pump can't draw fuel from a vacuum.
- Stu Harmon
Re: might be a crazy question. [Re: feets] #1686492
10/16/14 07:34 PM
10/16/14 07:34 PM
dogdays Offline
dogdays  Offline
Every 1971 car had an evaporative emission system and a non-vented gas tank. Yours is probably plugged or capped off or something. Fix it.
R.
Re: might be a crazy question. [Re: dogdays] #1686493
10/16/14 08:41 PM
10/16/14 08:41 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
Mine is a 70.. No concern here about emissions..
2011 RAM3500
Re: might be a crazy question. [Re: Boosted] #1686494
10/16/14 09:18 PM
10/16/14 09:18 PM
Georgia
Steve Bryant Offline
Georgia
1970 cars made in the LA Plant also had some of those emission "extras".
I did not replace the return fuel line on my 1970 Cuda when I stripped the undercarriage last year and so I "vented" my cap and used a PCV-like valve to let air go into the empty line instead of plugging it.
If I had plugged it and not opened the cap I would have been in the same boat.
