727 Front clutch clearance spec? #168612
12/16/08 06:18 PM
12/16/08 06:18 PM
Westphalia, Meeeeeshigan
MIRADAMANia Offline OP
I have a 70 727 that has 4 clutch plates. It was behind a 440 HP. What is the clearance spec?
Thanks!
Re: 727 Front clutch clearance spec? [Re: MIRADAMANia] #168613
12/16/08 07:45 PM
12/16/08 07:45 PM
4 clutches should have .048 to .055 clearance ..
Re: 727 Front clutch clearance spec? #168614
12/17/08 08:35 PM
12/17/08 08:35 PM
Thanks! Just curious where you got that?
Re: 727 Front clutch clearance spec? [Re: MIRADAMANia] #168615
12/17/08 08:38 PM
12/17/08 08:38 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
A little more to it than that !! ...what is your band type? ... lever ratio ? .... and how many springs in the piston?
Re: 727 Front clutch clearance spec? [Re: dOOc] #168616
12/18/08 01:02 PM
12/18/08 01:02 PM
It's a flex band, 3.8 lever, and 10 springs.
Re: 727 Front clutch clearance spec? [Re: MIRADAMANia] #168617
12/18/08 03:13 PM
12/18/08 03:13 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The 70 FSM front clutch chart is showing clearance value of .066 to .123 for the 440 HP 727 with 10 springs... with that being said I was told to shoot for around {+ or -}.010 for each clutch disc... Interestingly FWIW a NON HP 440 4 clutch unit with 6 springs is only calling for between .024 to .125...
Re: 727 Front clutch clearance spec? [Re: MIRADAMANia] #168618
12/18/08 04:52 PM
12/18/08 04:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A lot of builders use the .012"-.015" per disc rule. That would but a 4-disc clutch in the .048"-.060" range.
Re: 727 Front clutch clearance spec? [Re: dOOc] #168619
12/18/08 04:55 PM
12/18/08 04:55 PM
What does the band type and lever ratio have to do with the front clutch pack clearance ?
Re: 727 Front clutch clearance spec? #168620
12/18/08 05:01 PM
12/18/08 05:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Clutch & band timing to prevent shift overlap without a restrictor in the apply passage...
