70 b body fuse box help #1686115
10/15/14 04:21 AM
10/15/14 04:21 AM
sandwich IL
sublimehemi Offline OP
sandwich IL
Ok where does these 3 pink wires attach on which spade...the we're just laying there by the fuse box
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: 70 b body fuse box help [Re: sublimehemi] #1686116
10/15/14 04:36 AM
10/15/14 04:36 AM
sandwich IL
sandwich IL
back of fuse box spades....also which spade does the tic toc tach go?
Re: 70 b body fuse box help [Re: sublimehemi] #1686117
10/15/14 09:16 AM
10/15/14 09:16 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Do you have a wiring diagram? Pink wires should be for dome light and other interior lights(console and map) that light up when door is opened or dimmer switch turned all the way up. It's also constant power to the headlight switch, emergency flasher, brake light, and glove box light.
Re: 70 b body fuse box help [Re: sublimehemi] #1686118
10/15/14 11:14 AM
10/15/14 11:14 AM
the wiring diagrams at www.mymopar.com might show em
