Re: Sealing the 383 intake manifold
[Re: calrobb2000]
#1686044
10/15/14 03:02 AM
10/15/14 03:02 AM
Posts: 137 midwest - USA
69/70 Plymies
midwest - USA
hi stock cast intakes do not use any gasket other than the valley pan !
Are you kidding me? No wonder I'm having trouble. Gaskets were on the engine when I tore it down before the rebuild. Are the gaskets only used on aluminum intakes?
[Re: skicker]
#1686047
10/15/14 09:34 AM
10/15/14 09:34 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Since the 60s Ive just used the tins.Even on my 440 alum heads and intake its just tin.No leaks ever.Rocky
Chrysler Firepower
[Re: Pynzo]
#1686048
10/15/14 10:28 AM
10/15/14 10:28 AM
69/70 Plymies
midwest - USA
If a person does use the Copper RTV, do you apply it around all ports and on all connecting surfaces?
[Re: Pynzo]
#1686051
10/15/14 02:23 PM
10/15/14 02:23 PM
69/70 Plymies
midwest - USA
Just trying to get to the bottom of this question....Were the original 383 intake manifolds from the factory in 1970 with gasket/valley pan/gasket or just valley pan? I have seen both claims, which is correct? P.S. The shop wants me to mill the intake in order to get proper intake bolt alignment and use the paper gaskets along with the valley pan per AERA's and Hughes Engine's recommendations. Pynzo...10-4 on the use of the copper, matches the paint just like you say!
[Re: 69/70 Plymies]
#1686052
10/15/14 02:45 PM
10/15/14 02:45 PM
Posts: 1,456 Northern CA
streetkit
Northern CA
No paper gaskets from the factory. Valley pan only.
1973 Dodge D100
[Re: skicker]
#1686055
10/15/14 03:47 PM
10/15/14 03:47 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
That's what I did except I used the black rtv.
You better pray you don't have to take that intake off , ever ... it's going to be a mess getting that off .
OP , the paper gaskets that come with the valley tin are .030 thick EACH , of course you will have alignment issues.
I like to use an .015 thick gasket to help seal because I hate having to scrap off sealer So I usually have .015 taken off the intake so I can use them .
[Re: streetkit]
#1686056
10/15/14 03:48 PM
10/15/14 03:48 PM
JohnRR
U.S.S.A.
[Re: JohnRR]
#1686057
10/15/14 06:40 PM
10/15/14 06:40 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Factory used only the tin gasket. I have reused them many times with no sealing issues. Normally I install them dry, except for the "V" area by the corners, where I put a dab of RTV sealer. Tin gasket works well with both alum and iron intake. The paper shims are only to be used to space up an intake that has been decked (milled) to correct any mismatch.
