w2 questions #1685998
10/15/14 01:23 AM
10/15/14 01:23 AM
LI, new york
gmachinedart1 Offline OP
LI, new york
Hi everyone. I recently purchased a used 360/w2 limited circle track engine and have a few general questions.I don't have much info on the engine other that it is a 360 with unported w2 , solid flat tappet, victor intake , stainless roller rockers, roughly 10:1 compression and was being turned to 7200 rpm.I havnt heard it run yet and plan on brining it to the dyno to see if it is healthy or not before I install it in my 70 dart. I think I also plan to run the engine in its current configuration for now as well , with future plans to have heads ported and select a different cam. This is my first w2 engine.
I purchased a new set of TTI headers and noticed TTI is only selling the 1 7/8 headers with a 3.5" collector when they used to offer it in a 3" as well. I will be using the car mainly as a road course track day car. Does anyone think with a full 3" exhaust , the 3.5 collector will hurt torque or is this something I should lose sleep over? I was considering cutting off the 3.5 and use a 3" merge.
I would like to ck the valve lash before I run it ,Can anyone advise on what would be a good starting point ? With my current 360 iron head, HS roller rocker , solid set up I run .016I/.018E.
What would be a good starting point for holley carb size/cfm?
Car is 3300# w/driver , 5 spd ,355 gear.
any suggestions/advice appreciated
thank you
justin
Re: w2 questions [Re: gmachinedart1] #1685999
10/15/14 01:49 AM
10/15/14 01:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
There is 2 different type of W-2 heads.. econo and
race.. econo heads have cast in stands for the rocker
shafts... the race have a flat milled on them for stands
and both heads have long or standard valve lengths
available... the W-2 heads arent that good with out
porting... as for valve lash is it a roller or FT
cam but .018 would work for either with out issue...
as for the 3.5 collector... leave them on.. they help..
when I built my W-2 headers they are 1 7/8 pri with
3.5 collectors then I have elec dumps then 3" exhaust
to the rear bumper with the muffs just before the
bumper
Re: w2 questions [Re: gmachinedart1] #1686000
10/15/14 02:02 AM
10/15/14 02:02 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Regards valve lash, assuming the engine is complete and as it was ran, I would check the lash on all valves as it sits and make note of them. You will likely find the vast majority are the same, and maybe one or two are off/ have moved. Set those to where the rest all are. That's highly likely where they belong.
If the engine isn't complete and together......,the above won't do you any good... Lol
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: w2 questions [Re: MR_P_BODY] #1686001
10/15/14 02:14 AM
10/15/14 02:14 AM
LI, new york
LI, new york
ok, thanx. They are the race head but not sure if they are a long valve or not off hand. It is a FT cam. I noticed the amount of thread on the adjusters seems excessive. Is it possible this thing was run like this at sustained high rpm without a problem? As far as unported w2 , im just curious how it does on the dyno as is. I was told it made mid 500hp, we'll see.
Re: w2 questions [Re: gmachinedart1] #1686002
10/15/14 02:15 AM
10/15/14 02:15 AM
LI, new york
LI, new york
pics
Re: w2 questions [Re: gmachinedart1] #1686003
10/15/14 02:18 AM
10/15/14 02:18 AM
LI, new york
LI, new york
pic
Re: w2 questions [Re: gmachinedart1] #1686004
10/15/14 02:19 AM
10/15/14 02:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The adjusters would just say to me that the PRs are
a bit short... is it best... no.. it tends to side
load the adjusters much harder the farther out they are
Re: w2 questions [Re: MR_P_BODY] #1686005
10/15/14 02:28 AM
10/15/14 02:28 AM
LI, new york
LI, new york
adjuster
Re: w2 questions [Re: gmachinedart1] #1686006
10/15/14 02:31 AM
10/15/14 02:31 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I shoot for 2 threads showing. Let us know what it makes.
Sheldon
Re: w2 questions [Re: gmachinedart1] #1686007
10/15/14 02:33 AM
10/15/14 02:33 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
adjuster
That`s WAY wrong in my opinion for both oiling and strength.........
Re: w2 questions [Re: Thumperdart] #1686008
10/15/14 02:38 AM
10/15/14 02:38 AM
LI, new york
LI, new york
Im waiting for my milodon road race pan, I will let you know what it does.
Thumper , I agree. Im assuming a longer pushrod will correct this.
Re: w2 questions [Re: gmachinedart1] #1686009
10/15/14 02:41 AM
10/15/14 02:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When I set up the PR length I do a couple of checks
first.. I have a tool I made up so I can put a rocker
on it and see if the roller tip and the center line
of the shaft is in line and where the actual pivot
of the PR should be(down in the cup)... they should
all be in a line... some might want 1 thread showing
and some might want more or less
Re: w2 questions [Re: gmachinedart1] #1686010
10/15/14 02:46 AM
10/15/14 02:46 AM
LI, new york
LI, new york
understood
thank you
Re: w2 questions [Re: gmachinedart1] #1686011
10/15/14 02:51 AM
10/15/14 02:51 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I feel sorry for your Hoosiers.
Mopar to the bone!!!
Re: w2 questions [Re: gmachinedart1] #1686012
10/15/14 09:20 AM
10/15/14 09:20 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
adjuster
That BLUE pushrod tells a story.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: w2 questions [Re: pittsburghracer] #1686013
10/15/14 11:09 AM
10/15/14 11:09 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
adjuster
Absolutely, look at the burnt on oil on the pr cup.
Re: w2 questions [Re: gmachinedart1] #1686014
10/15/14 07:30 PM
10/15/14 07:30 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
Any idea who built it? I have two W-2 engines. A low 400hp 340 that sounds like the build you have and a Bill Richardson built 380 that puts out 550hp. Just by looking at the way they ran those adjusters I wouldn't run it without checking everything. Too risky to me.
Re: w2 questions [Re: pittsburghracer] #1686015
10/15/14 07:54 PM
10/15/14 07:54 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
adjuster
Could be from manufacture of the pushrod.
Yeah, it's got a smallblock.
Re: w2 questions [Re: 340B5] #1686016
10/15/14 09:53 PM
10/15/14 09:53 PM
PA.
"Little"John
"Little"John
PA.
adjuster
If t is I would never buy pushrods from that manufacturer.
No one in their right mind would sell a product looking like that.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: w2 questions [Re: gmachinedart1] #1686017
10/15/14 10:02 PM
10/15/14 10:02 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Hey, if you would like a visual reference on a real live running W2 small block, you are welcome to come take a look at my junk. W2/340, MP .557 solid, Victor, TTi step headers.
I'm up in Huntington. PM me if you're interested.
'71 Duster
'72 Challenger
'17 Ram 1500
