727 Fluid- What and Why? #1685820
10/14/14 05:18 PM
10/14/14 05:18 PM
North Austin
KnuckleDuster Offline OP
North Austin
Title says it, what do you run,and your reasoning?
Re: 727 Fluid- What and Why? [Re: KnuckleDuster] #1685821
10/14/14 05:50 PM
10/14/14 05:50 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Type F.
I've run it because that's what Mopar recommends.
Never had an issue.
Re: 727 Fluid- What and Why? [Re: GY3] #1685822
10/14/14 05:52 PM
10/14/14 05:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 727 Fluid- What and Why? [Re: stumpy] #1685823
10/14/14 05:53 PM
10/14/14 05:53 PM
an8sec70cuda Offline
Type F here too.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 Fluid- What and Why? [Re: an8sec70cuda] #1685824
10/14/14 06:30 PM
10/14/14 06:30 PM
Cheap Type F is all you will ever need
The type F has different friction coefficient than Mercon--additive pkg
It is funny how trannys can be very picky about fluid
My dad buys lots of Crown Vics with trans trouble--replaces the fluid with FORD brand and shudder issues go away like magic--replace it with correct kind different brand and Bamn same trouble--
Time and temp eat up the additives and kill fluid
Fresh Walmart Type F is all you ever need--replace it every year or more often if you have any stall
Many folks run way too loose a converter on the street and that Kills fluid fast--fresh is best and I have never seen et or shift improvment with more expensive fluid
I run Walmart F in a dragster so.....
Re: 727 Fluid- What and Why? [Re: ] #1685825
10/14/14 06:48 PM
10/14/14 06:48 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Really curious about this:
"Selection of Lubricant
Use only fluids of the type labeled DEXRON Automatic
Transmission Fluid or Chrysler Automatic
Transmission, Fluid AQ-ATF-2848A, or there equivalent."
How did we get from Dexron to using type F in Chrysler products? That was a big nono when I was a mechanic. I've been using the newer +4 stuff since nothing else looked remotely similar to what I used to see. Last time I looked I couldn't even find Dexron II.
My '69 Chrysler needs transmission service soon.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 727 Fluid- What and Why? [Re: 3hundred] #1685826
10/14/14 09:41 PM
10/14/14 09:41 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Yes...Ditto
Re: 727 Fluid- What and Why? [Re: dmoore] #1685827
10/14/14 10:52 PM
10/14/14 10:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Lots of racers use type-F because it will work very good when you have no lock-up converter and you dont have to worry about the car getting hot in the hot summer with the ac and all on. Thats where the Mopar ATF+4 works very good as its a good trans fluid and is the best to use in newer Mopars. In race cars and our hot rods without lock-converters and all the type-F works good where you dont get very hot under hood temps like newer cars and I believe it does not have the slippage friction that newer fluids have that have to work with lock-up converters. So type-F they say has less slipage and works good in the older tranny's. Myself I have a good amount of the Mopar ATF+4 since I worked at a Dodge dealer for about 24 years so thats all I use in mine and it has worked good for me. I have the Mopar ATF+4 in my sons Dart thats used it since 1997 and the fluid is still super clean as it has been changed twice since then. Course its a low milage street car and the same for my 63 as the fluid and trans look like new and the shifts are nice and firm. The ATF+4 has worked fine for me. Ron
Re: 727 Fluid- What and Why? [Re: 383man] #1685828
10/14/14 11:02 PM
10/14/14 11:02 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
pretty much what 383man said.... I work at a dealer and have access to +4 cheap. I hauled my race trans over to Pro Trans for some updates years ago and brought this topic up.... he said run the red stuff ....but did agree that +4 was a good fluid and to continue it's use.
Re: 727 Fluid- What and Why? [Re: J_BODY] #1685829
10/14/14 11:27 PM
10/14/14 11:27 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Type F because that's what my trans builder said to run. It works.
Re: 727 Fluid- What and Why? [Re: Chilort] #1685830
10/15/14 12:20 AM
10/15/14 12:20 AM
SE PA
Yellow Fever Offline
SE PA
I always used type F then my brother in-law who has a trans shop gave me dexron with a new rebuild, ran just as good as the type F. Don't think it really matters, just don't mix em. If I got ATF+4 cheap then I'd use that.
Re: 727 Fluid- What and Why? [Re: Yellow Fever] #1685831
10/15/14 11:56 AM
10/15/14 11:56 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Why is mixing them a bad idea?
Re: 727 Fluid- What and Why? [Re: mopowers] #1685832
10/15/14 04:07 PM
10/15/14 04:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No problem mixing fluids, my personal mix is a 50/50 blend of Dexron and Type F.
Re: 727 Fluid- What and Why? [Re: John_Kunkel] #1685833
10/15/14 04:19 PM
10/15/14 04:19 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
From what you guys have posted and some other stuff I've read, you want to be sure to pour in the red stuff in your older non lockup GM and Chrysler transmissions.
I think I'm going to go with 7176+4 when I do my Chrysler fluid change. Just because.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: 727 Fluid- What and Why? [Re: 3hundred] #1685834
10/15/14 05:01 PM
10/15/14 05:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I use type F to protect the clutches, they are the most common failure I see by a long shot, bearings and gears not so much. The type F allows the clutches to live longer, +4 is to make soft shifts and protect bearings and gears. In reality the difference is barely noticable from type F to +4. All the dex merc stuff seems to be somewhere in the middle and you should have no issues mixing them.
Re: 727 Fluid- What and Why? [Re: HotRodDave] #1685835
10/15/14 05:07 PM
10/15/14 05:07 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
My Chrysler has the original 1969 transmission, less than 60,000 miles. I know I had it changed at ~ 52,000 miles but it's been about 10 years now and the gasket is leaking again. What do you think would be best for my situation? We don't drive it hard at all and almost no highway driving.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: 727 Fluid- What and Why? [Re: 3hundred] #1685836
10/15/14 05:32 PM
10/15/14 05:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Type F.
Re: 727 Fluid- What and Why? [Re: KnuckleDuster] #1685837
10/15/14 05:42 PM
10/15/14 05:42 PM
Earth
Rob C Offline
Rob C  Offline
Earth
ATF+4
Re: 727 Fluid- What and Why? [Re: Rob C] #1685838
10/15/14 05:50 PM
10/15/14 05:50 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Type F.
ATF+4
LOL
I remember reading, long ago that B&M trick shift was basically just colored type F with the price tripled. It was advertised to firm up shifts. I'm thinking less slippage would be good for the longevity of my antique transmission, even if the difference is minimal. I know the advantage of synthetics, this car meets none of the criteria even if my personal preference is to stick with a Chrysler fluid product. And I may yet.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: 727 Fluid- What and Why? [Re: Rob C] #1685839
10/15/14 06:54 PM
10/15/14 06:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
ATF+4 is formulated for transmissions with lockup converters and overdrive gears that run constantly...not features that you find in the majority of performance 727's.
Although Mopar says it is backwards compatible with previous fluids and recommends it for older 727's they do that mostly to be able to stock just one fluid in their service/parts departments rather than 3 or 4.
