Indybrock flow results & pics
#1685793
10/14/14 04:20 PM
10/14/14 04:20 PM
Posts: 128 Finland
mopster
Finland
Re: Indybrock flow results & pics
[Re: BradH]
#1685796
10/14/14 07:23 PM
10/14/14 07:23 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Yay! Real tech info!
What he said.
[Re: Quicktree]
#1685798
10/14/14 08:56 PM
10/14/14 08:56 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
they are a good head that works well mine flowed 317 with a 2.055 valve and they went every bit of 650hp on a 416
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1913215
09/15/15 08:05 PM
09/15/15 08:05 PM
Posts: 128 Finland
mopster
Finland
This is an old topic, but I never updated the rest of the engine combo or the dyno/track results, so here we go. Better late than never. Engine specs: X-block, half fill, 4-bolt mains 4.080" bore, 4" stroke, 6.250" sbc rods 12.6:1 custom pistons mech flat tappet cam 272/276@.050", .611/.627" lift, 106lsa M1 tunnelram, Q-750-E85CT carbs 1 7/8" hedman husler headers It made 641hp@6600 and 561ft/lb@5000 on the dyno. The cam is definitely holding back the power, and the compression is pretty mild too, but on the other hand this is a street car engine, not an all out race engine. This engine is now in my street Duster, 3370lbs, footbrake, 727, S60. Best ET 10.41 / 129.77mph And heres the car in action, a video of a trip to a racetrack. https://www.youtube.com/watch?v=vEL7I71V6h4
[Re: mopster]
#1913284
09/15/15 09:53 PM
09/15/15 09:53 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
This is an old topic, but I never updated the rest of the engine combo or the dyno/track results, so here we go. Better late than never. Engine specs: X-block, half fill, 4-bolt mains 4.080" bore, 4" stroke, 6.250" sbc rods 12.6:1 custom pistons mech flat tappet cam 272/276@.050", .611/.627" lift, 106lsa M1 tunnelram, Q-750-E85CT carbs 1 7/8" hedman husler headers It made 641hp@6600 and 561ft/lb@5000 on the dyno. The cam is definitely holding back the power, and the compression is pretty mild too, but on the other hand this is a street car engine, not an all out race engine. This engine is now in my street Duster, 3370lbs, footbrake, 727, S60. Best ET 10.41 / 129.77mph And heres the car in action, a video of a trip to a racetrack. https://www.youtube.com/watch?v=vEL7I71V6h4 I see 761 tq...................
[Re: Thumperdart]
#1913312
09/15/15 10:16 PM
09/15/15 10:16 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
Thumper and andyf that's 761 newton meters which equals 561 ft lbs.
[Re: GomangoCuda]
#1913352
09/15/15 10:47 PM
09/15/15 10:47 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
WOW my sons .040 over stock crank 360 that has gone 10.50's at 3150 pounds with a 520 lift cam and Edelbrock heads must make a few more HP than I figured.
[Re: mopster]
#1913414
09/16/15 12:23 AM
09/16/15 12:23 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I like the MPH. Almost 130 at 3370 is making some steam( if thats right) I went 129+ with a 260@50 flat tappet and W5 heads on my cast crank 416 one summer before the crank broke( 727 tranny, 3350 weight) but it wasn't more than maybe 600 horse to do that.... Maybe. Tti headers and a 4150 carb, about 11.5 compression. I don't know around here if I would call a tunnel ram, 12.6 compression, and a huge 272@50 cam street able...... But, you guys have bad weather 9 months a year over there, and cold/ cool weather the other 3 months, short season, so I guess anything is street able...... Lol
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: GomangoCuda]
#1913461
09/16/15 01:27 AM
09/16/15 01:27 AM
Thumperdart
State of confusion
Thumper and andyf that's 761 newton meters which equals 561 ft lbs. Gotcha................
[Re: mopster]
#1913733
09/16/15 03:05 PM
09/16/15 03:05 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Someone always has to pee in someone elses cerial.
Perhaps the rest of the combo is not sorted out yet as well as your sons. He does have more weight and is still faster. May need to work on shift points, gearing, converter, maybe his fuel system need some work... a million things can change from dyno to track, dyno is just a fun tool but a valuable tool no less. I know you don't race a dyno but there is a lot more to what happens on the track than just a HP number.
For what it's worth I think ANdyF is right about the cam.
