Tips, tricks, triumphs and screw ups recovering seats??
#168554
12/16/08 04:04 PM
12/16/08 04:04 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
I'm thinking about recovering the bucket seats in my '70 Cuda as a nice winter project, and hoping to gather some information on what to expect before I dig in. Interested in stories, tips, tricks or tales of woe that anyone can share from their own experiences. Photos always appreciated. Thanks
Re: Tips, tricks, triumphs and screw ups recovering seats??
[Re: rss]
#168555
12/16/08 04:16 PM
12/16/08 04:16 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
Hey Russ! I did a set many years ago. Turned out great. My thoughts: The rear bench is easy, do it first as a warm up, the buckets are much more work, though not "Hard"
Use new foam, I know its expensive, but re-using old foam is a compromise Do it in the sun, (winter project????) or at least get the vinyl good and warm--it makes a difference. Get a good set of hog ring pliers, and preferrably a set without a bunch of extra metal at the tip---you want to be able to reach the tip as far into the work as possible. I ground the tip down on mine on a grinder to accomplish that. Get two sizes of hog rings, there will be times when you want a choice. The buckets are all about securing the listing wires evenly, tightly, and securely. My finger tips were sore for a few days afterwards. Obviously be very careful not to puncture the vinyl with a hog ring.
I don't recall the order-of-operation, I think you start in the middle and work back and forth, side to side, to ensure it finishes evenly. Work wrinkles out as you go--do not expect them to work themselves out. One of the trickiest areas are the seat backs, sort of where your shoulders would be (right at the transition from head reast to seat back).
Good luck Make sure the seat springs are in good shape.
[Re: rss]
#168557
12/17/08 03:34 AM
12/17/08 03:34 AM
Posts: 616 Sacramento, CA
Kirk_Ingram
super street
super street
Sacramento, CA
It really helps to have a second person to compress the new foam while you pull the new vinyl into place, and hog ring it in. I.E. have a helper put their body weight on to compress; result is a nice wrinkle-free fit. And bucket seats usually have an inset; measure carefully for the new cuts and DON'T secure those 'til your certain they are at least CLOSE. another
Death or Glory...it's just another story.
[Re: Kirk_Ingram]
#168558
12/17/08 11:38 AM
12/17/08 11:38 AM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
buckets are hard but time consuming,only do one at a time as then you have the other to look at,believe me on this,also get new burlap from a fabric store and like said new foam(dante)the sun really does help,also i put trash bags over the foam to help slide the cover on then you can reach and ripe out the plastic later. pm me so i remember to send you a copy of instructions to do this when i get home. Darren
[Re: 70Duster440]
#168564
12/17/08 03:24 PM
12/17/08 03:24 PM
Pacnorthcuda
Some silicone spray will help in pulling the covers over foam. Get a decent pair of hog ring pliers. Your hands will thank you.
I stitched up rear covers from scratch to match my aftermarket buckets. Easier than buckets, of course.
I've also heard of people using garbage bag plastic over the foam, pull the upholstery into position, then pull plastic out. Supposedly works real well--I didn't try it myself, but seems like it would work.
[Re: Pacnorthcuda]
#168565
12/17/08 03:55 PM
12/17/08 03:55 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
I did my front Challenger buckets a while back using a Legendary kit and it worked well, but took me around 8 hours per seat to do. There was an article in Mopar Muscle or Mopar Action in the late 90's on this very subject that was really helpful if you have a stash of old car mags you should look for it. I do remember that for the bottom especially, you needed to be careful pulling the cover in to place to avoid ripping it. My old foam was in good shape other than an area where a mouse had chewed up. I reused my foam but had bought some foam squares and made up a section to replace the damaged area, and glued it in place. The hog rings can be a pain to remove and to get in place when installing the new cover, when doing a seat with a lot of contours like an ebody bucket. Buy a couple of good wire cutters from a company with a liberal warranty return policy like Craftsman or Klein, as you are almost guaranteed to break a pair or two during your cutting of all the old hog rings and the ones you don't get in the proper place with the new cover when installing (which will happen). Don't worry too much if there are some small wrinkles or creases in the vinyl after you are done. Usually after the the seats sit in the sun for a while small imperfections will go away, at least thats what happened with my seats. A friend helped me with my first seat, who had done a early 70's Monte Carlo seat before and said this job was easy. He changed his mind about the ease of this job with my Challenger seat! I later redid the seats for a Piper airplane using an Airtex kit and they were pretty easy. Unfortunately E body buckets seem to be some of the hardest seats to do. I am really happy with the results, my seats look great! However my other Challengers front seats could use new covers too, and I haven't gotten too ambitious about tackling them yet.
[Re: Mastershake340]
#168567
12/17/08 04:09 PM
12/17/08 04:09 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
The last seats I had recovered were back in the 80s and were for a 66 Mustang. My Challenger needed the seats covered and thought it had been a while I did not hesitate doing it. To me, it is one of the easier jobs of the restoration process.
First, make sure you have a well made cover...I bought Legendary covers from Dante and the fit and quality was excellent. Just take your time and you will do fine. Make sure you have a good set of hog ring pliers and some hog rings. One tip on Hog Rings is that I went down to a local upholstery shop and the guy just gave me bunch so I did not have to buy any. You might do the same or get them for less than what they would cost if you ordered them. Warming the covers before putting them on is Key. I did mine in the fall and the days were still warm so I put them in the sun for a short while. That really helped with the install. The only problem I ran into was with one of my seat frames. The foam was OK on all my seats but the lower driver seat frame had areas that the wires had broken. I replaced them and repaired them with wire I got from the hardware store. I don't have a photo of the front ones but here is a photo of the rear. Front ones turned out just as nice. BTW, make sure you clean and paint your seat frames while you have everything apart.
Good Luck, Joe
65 Barracuda 70 Challenger
[Re: dustergirl340]
#168568
12/17/08 04:13 PM
12/17/08 04:13 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I make my own seat covers, that's where the work is...just putting them on is a piece of cake.
Kathrine, I'm planning on doing the same. Looking for a vinyl source locally. Did you make your own patterns? find one? reverse engineer the old ones?(which is how I figured I would do it)
[Re: Oldstrtracr]
#168572
12/17/08 05:37 PM
12/17/08 05:37 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
What are some good quality brands, of hog ring pliers?
I borrowed my pliers from a buddy that had them. I don't know the brand but this is a photo of them. They had a slight bend in them and worked great.
Joe
