Re: Changing jets in a Edlebrock 800 Thunder???
[Re: okie]
#1685326
10/13/14 10:52 PM
10/13/14 10:52 PM
Posts: 3,916 usa
lewtot184
usa
How do you determine which spring to use? That is a different chart than in the book I have. Mine has 2 107 jets listed in it but different rods. I'm just trying to get it not to run so rich. I'm rebuilding my motor now so I need to try to get it close as I can. There isn't any place around me to put it on a dyno. Thanks Ronnie
do the 107's in the primarys and keep the 68x47 rods and orange springs that the carb came with. try 104 or 101's in the back. use a smaller squirter up front, nothing bigger than a .028. it's easy to do. test with a vacuum gauge to make sure you have over 5" of manifold vacuum at idle in gear.
Re: Changing jets in a Edlebrock 800 Thunder??? *DELETED* *DELETED* *DELETED* *DELETED* *DELETED*
[Re: Cab_Burge]
#1685328
10/13/14 11:15 PM
10/13/14 11:15 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
[Re: lewtot184]
#1685330
10/14/14 10:10 AM
10/14/14 10:10 AM
Posts: 1,222 okla.
okie
okla.
Where and how do I get and change the squirter?
[Re: Sammy]
#1685331
10/14/14 10:13 AM
10/14/14 10:13 AM
Posts: 3,916 usa
lewtot184
usa
7147 rods will make that car purr. Orange springs and put accelerator rod in top hole. .104 primary, and .101 secondary End of story.
this is worth a try, but from my experience, the big squirter has to go. after messing with a friends 800avs i've found that these carbs can be made to drive nicely and make power.
