904 trans question #1685186
10/13/14 02:37 PM
10/13/14 02:37 PM
Pottstown, Pa.
sg1093 Offline OP
sg1093  Offline OP
Pottstown, Pa.
I am rebuilding a 904 for my brother, was built by a well known trans and converter builder. On dissassembly, I found the larger diameter spring for the front kickdown servo missing. Has anyone else run into this? I do not know of any reason for leaving it out. Any suggestions?
Re: 904 trans question [Re: sg1093] #1685187
10/13/14 03:12 PM
10/13/14 03:12 PM
Guitar Jones Offline
I don't leave them out but different years had different servo designs.
Re: 904 trans question [Re: sg1093] #1685188
10/13/14 03:39 PM
10/13/14 03:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Prior to '71 most (all?) 904 kickdown servos had only the smaller inner spring.
Re: 904 trans question [Re: John_Kunkel] #1685189
10/13/14 07:37 PM
10/13/14 07:37 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Bingo
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 904 trans question [Re: dusturbd340W5] #1685190
10/14/14 01:43 PM
10/14/14 01:43 PM
Pottstown, Pa.
sg1093 Offline OP
sg1093  Offline OP
Pottstown, Pa.
Thanks for the replies. It is a 1974 trans case, and does not have a load control servo. I disassembled another trans with the same type servo and removed the larger diameter spring and installed it in the 1974 case. I guess I will find out how it works. My thought is that the band will release quicker with the added spring tension.
