Re: 68 B body rear window removal
[Re: belv2vert66]
#168499
12/16/08 06:07 PM
12/16/08 06:07 PM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
From the outside, I used a utility knife and kept cutting away the material until I was celar down to the sheet metal. Then, from the inside, I worked a modified putty knife to "pull out" the adhesive. I took a cheap harbor freight putty knife and ground a hook on the end. I also bent the blade a little bit so I could have a good hold. Took about two hours of work. I did not even think about putting pressure on the glass until I could fish the putty knife all the way around the glass. The butyl stays pretty sticky so a little even force to puch the glass out was still needed after I went around the window a few times.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
