Steering Column for a 67 Belv/GTX #1684865
10/12/14 06:59 PM
10/12/14 06:59 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
What columns will fit this car? Mine was P/S and now converting to manual.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Steering Column for a 67 Belv/GTX [Re: Boosted] #1684866
10/12/14 07:18 PM
10/12/14 07:18 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
A 1966 model will not work due to the turn signal switch, tube diameter/type (non-crush style) and a few other minor differences. It could be made to work if you find one cheap. I think the first year of the key switch being located on the column itself would be 1970 in a b body? Can anyone confirm this? Basically you should be able to use any manual steering column from a 67 up b body that had the ignition key and emergency flashers located on the dashboard.
Re: Steering Column for a 67 Belv/GTX [Re: Jeremiah] #1684867
10/13/14 11:28 AM
10/13/14 11:28 AM
GA
Boosted Offline OP
Boosted  Offline OP
GA
Thank you for the heads up.. I will do some searching.
2011 RAM3500
