06 Charger high pressure power steering hose change out #1684837
10/12/14 04:40 PM
10/12/14 04:40 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
This just a "change it and go" process, or do I need to be worried about creating air pockets in the power rack and pinion? Thanks in advance for help.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: 06 Charger high pressure power steering hose change out [Re: RTDaddy] #1684838
10/12/14 05:33 PM
10/12/14 05:33 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Changed a lot of hoses at work.Just crank lock to lock a few times and any air pockets should be gone.Typically you have to add fluid also after doing it.I usually have just enough to see and start the car.It will usually suck it donw then add easy.Rocky
Chrysler Firepower
Re: 06 Charger high pressure power steering hose change out [Re: therocks] #1684839
10/12/14 06:34 PM
10/12/14 06:34 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
Thanks Rock
