Addco 541 swaybar installed...1969 Plymouth B-Body #1684701
10/11/14 11:58 PM
10/11/14 11:58 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Finally completed my disk-o-tech upgrade and Addco 541 swaybar install - along with replacing every bushing in the front end.
Have to say after years of putting this off it was way easier than anticipated - hardest part was getting out the rusty cam bolts in the uppers.
Sway bar install was super easy - the hardware change Addco made a few years ago must have done the trick - it took about an hour to install.
Method I used was to
-raise front end
-remove wheels and install brackets at lower shock - leave loose
-remove the K-member to lower rad support bracket thing
-drill out holes in K-member to pass mounting bolts
-loosely install K-member brackets
-use sway bar bushings and brackets loosely installed to hang sway bar
-point bar in the right direction
-put wheels back on
-drop car back onto ground
-install end links loosely - building stack from bottom to top - starting with side that required the longest end link
-tighten all K member mount bolts and bar mounts
-angle lower shock brackets properly and tighten them down
-tighten end links
-install the K-member to lower rad support bracket thing
Check out picks - hope this helps someone else in the future - the instructions are non-existent for this bar
Now onto the rear...
Plazomat
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: plazomat] #1684702
10/12/14 12:00 AM
10/12/14 12:00 AM
plazomat Offline OP
plazomat  Offline OP
Pic#2
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: plazomat] #1684703
10/12/14 12:01 AM
10/12/14 12:01 AM
plazomat Offline OP
plazomat  Offline OP
Pic#3
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: plazomat] #1684704
10/12/14 12:04 AM
10/12/14 12:04 AM
plazomat Offline OP
plazomat  Offline OP
PM me if anyone has questions - I'd be glad to help - Addco surely can't...
BTW - that is 10.98 in disks with pin calipers under a 14 inch Centerline auto drag...
This is the front end stance for now...
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: plazomat] #1684705
10/12/14 12:19 AM
10/12/14 12:19 AM
Central TX
roe Offline
roe  Offline
Central TX
If you haven't had one on there previously , you are going to love your sway bar after you take your first turn or take a hard curve with speed. Adding one to my car has been the single best handling upgrade on my car.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: roe] #1684706
10/12/14 11:08 AM
10/12/14 11:08 AM
plazomat Offline OP
plazomat  Offline OP
No previous bar, hope it makes a world of difference, school bus handling wasn't any fun.
Did you use a rear bar? Which one? I got and Addco 7/8 waiting to go on..
Plaz
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: plazomat] #1684707
10/12/14 07:12 PM
10/12/14 07:12 PM
Central TX
roe Offline
roe  Offline
Central TX
Plaz
No I only used a front bar and it still made a night and day difference. And it was just a stock sized bar that I pulled from the j/y. I still want to add a rear bar as well.
What size is your front bar? What's the recommendation of bar sizes when uses both? Should they be the same size or should one be larger than the other?
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: roe] #1684708
10/12/14 11:32 PM
10/12/14 11:32 PM
plazomat Offline OP
plazomat  Offline OP
My front bar is a 1 1/8 inch bar, Addco only makes a 3/4 or 7/8 rear bar. I have the 3/4 bar not the 7/8 like I thought.
I don't think they are supposed to be the same - but I am sure a guru on this board will have a suggestion..
Plaz
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: plazomat] #1684709
10/13/14 11:19 AM
10/13/14 11:19 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The bars are rarely the same size. Proper sizing depends on the spring weights, weight of the car, balance of the car, and a few other things.
In general, the rear bar will be significantly smaller than the front to promote a more controllable understeer at the limit.
I used a factory 7/8" bar on the front of the hot rod and a 3/4" bar on the rear. It handled fairly well.
- Stu Harmon
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: feets] #1684710
10/14/14 12:57 PM
10/14/14 12:57 PM
plazomat Offline OP
plazomat  Offline OP
Feets,
There are so many options for torsion bar and leaf springs on the market - how do you properly size the swaybars? Is there a formula or calculator etc that you used?
Plazomat
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: plazomat] #1684711
10/16/14 05:46 PM
10/16/14 05:46 PM
My hovercraft is full of eels
DaveKanofsky Offline
Thanks for posting this Plazomat, we are going to get that kit for my dad's '66 Coronet.
I emailed Addco, and attached are their installation instructions...
8302355-541_revised.pdf (328 downloads)
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: DaveKanofsky] #1684712
10/16/14 09:45 PM
10/16/14 09:45 PM
plazomat Offline OP
plazomat  Offline OP
No problem - at least they got back to you...
Let me know if you need any more pics or help..
Plaz
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: plazomat] #1684713
10/17/14 01:35 AM
10/17/14 01:35 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Feets,
Plazomat
There are tons of formulas and calculators. What it comes down to is personal taste.
Some like big springs and small bars. Others like small springs and big bars. Others want big everything.
To race competitively, you have to calculate the roll rate of end end of the car using the suspension geometry and vehicle weight to determine the most effective bar for your combo.
That gets kinda messy so most places default to a bigger front bar than rear bar. The stiffer front suspension will make the car understeer when pushed. That is easier to control than a rear end trying to come around.
- Stu Harmon
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: feets] #1684714
10/24/14 11:57 PM
10/24/14 11:57 PM
plazomat Offline OP
plazomat  Offline OP
Took it out for a drive today, man what a difference that bar makes from no bar...I can really toss it around now and car has hardly any lean and just feels so crisp and planted firm..
Now the brakes...well they just suck - not sure what exactly I did wrong but it stopped better with manual drums on the front..
Plazomat
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: plazomat] #1684715
10/25/14 12:56 AM
10/25/14 12:56 AM
Central TX
roe Offline
roe  Offline
Central TX
Plazomat
I told you that thing would make a huge difference. Enjoy.
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: roe] #1684716
10/26/14 06:50 PM
10/26/14 06:50 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
That front suspension looks great. I can imagine how much difference no bar to bar would make.
Is your pedal hard now, or sinking, or what?
Facts are stubborn things.
Re: Addco 541 swaybar installed...1969 Plymouth B-Body [Re: larrymopar360] #1684717
11/11/14 12:28 AM
11/11/14 12:28 AM
plazomat Offline OP
plazomat  Offline OP
Sorry Larry just saw this...pedal just sucks but I did somethings wrong have another thread on that with lots of suggestions from the gurus on this board as usual..have not had time to work on it...she will be right eventually.
PLAZ
