440 Rear Main Seal Cap Fastener Size Needed #1684588
10/11/14 09:10 PM
10/11/14 09:10 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I'm in the process of rebuilding my first engine and I'm not sure what size fasteners retain the rear main seal cap on a 440. I had to remove some RTV from the two fastener heads, but they do not appear to be SAE. Please refer to the photo. Any thoughts?
Re: 440 Rear Main Seal Cap Fastener Size Needed [Re: vinnyd76] #1684589
10/11/14 09:24 PM
10/11/14 09:24 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I believe they are 3/8" 12 point
Re: 440 Rear Main Seal Cap Fastener Size Needed [Re: vinnyd76] #1684590
10/11/14 09:24 PM
10/11/14 09:24 PM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
3/8 12 point socket. Lol, just seen the post above, maybe I am incorrect, been awhile .
Re: 440 Rear Main Seal Cap Fastener Size Needed [Re: mopar4ya] #1684591
10/11/14 09:32 PM
10/11/14 09:32 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
No, your "on point"...... had to check for myself. Thought is was 7/16" 12 point so I edited my post
Re: 440 Rear Main Seal Cap Fastener Size Needed [Re: roadhazard] #1684592
10/11/14 10:16 PM
10/11/14 10:16 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the quick response! I believe I was using a 6 point socket today. I will locate a 12-point socket tomorrow and try again.
Re: 440 Rear Main Seal Cap Fastener Size Needed [Re: vinnyd76] #1684593
10/11/14 11:24 PM
10/11/14 11:24 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Make sure you get a good quality 12-point socket. This is a 3/8-16 bolt, usually torqued around 30 pounds, if you've already used the wrong socket you may have already rounded off some of the edges, the last thing you want to do is knock the edges off so that no socket fits, if that happens, the rest of your day will not be a happy one.....
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
