Re: Losing voltage somewhere
[Re: mopower440]
#1684515
10/11/14 07:56 PM
10/11/14 07:56 PM
RapidRobert
all stock wiring. Any ideas where to look? Is it possible to install the petronix kit into an ELECTRONIC distributor like you can a points unit so i can do away with all the factory crap?
Clean all the terminals on the firewall bulkhead (male terminal NAPA 725147) to clean the female halves and a wire brush for the male ones & koppercoat for continuity/dielectric grease to seal em away from air then as needed check running voltage drops at every terminal/connection or just clean em ALL from battery in/thru bulkhead/under dash connections/out thru bulkhead. Check/clean ground path also. EDIT For a chemical to aid in cleaning reportedly "Deoxit" is VG for cleaning terminals (I'm gonna try it). Not sure who sells it but it'd be easy to find out
[Re: mopower440]
#1684516
10/12/14 02:45 AM
10/12/14 02:45 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I found on my 70 Challenger that the wiring from the ignition switch where it exits the steering column and via the 6 wire connector(plus any optional wires such as key warning) that plugs into dash harness connector is where there is opportunity for much mischief.
What happens is that the male pins from the dash harness can begin to fit loosely into their corresponding female receptibles,,,thereby causing the random electrical circuit errors that you appear to be experiencing.
I created a somewhat Bubba fix that has resolved it quite well for my problem(s) in this area. The only true/correct fix is to replace both the ignition switch and the under dash harness,,,so far I've only done the ignition switch part.
The description of my Bubba solution, though simple, requires a bunch of words to describe how. If anyone should ask, I will post what I have done that seems to be holding quite well.
Meanwhile, if you do experience a start failure, just reach down, grab hold of this connector while cranking. If engine fires off, you know where your problem lies.
Also with a test light or meter you can easily test out all these 6 wires(they all are critical to starting and running of your engine) for continuity while wiggling this 6 wire connector about.
You also might separate this connector and spray some contac cleaner about,,,this May or may not solve the problem if it proves out to be in this area.
[Re: mopower440]
#1684518
10/13/14 03:46 PM
10/13/14 03:46 PM
Posts: 10,222 Someplace you aren't
SomeCarGuy
The key word in there I see is "sometimes." I would look for a loose or broken wire. First place I would check is to be sure the ECU has a good ground. I usually just run a wire to good ground and be done with it. I'm not sure what coil you have but we have debated on here plenty about how much voltage to send to one. That sure sounds like it is low.
I want my fair share
[Re: mopower440]
#1684519
10/14/14 09:25 AM
10/14/14 09:25 AM
Posts: 10,749 North Dakota
6PakBee
North Dakota
Sounds like the problem is not with the ignition but the power supply to the ignition. By jumpering the '+' side of the coil to the battery you are bypassing the ignition switch, ballast resistor, and wiring harness. Your problem lies somewhere there, you just have to find it. As to the coil operating at less than battery voltage, the ECU operates at full battery voltage but the coil is fed through the ballast resistor. I would recommend looking at the schematic for the ignition just to see where everything goes.
[Re: mopower440]
#1684522
10/14/14 02:55 PM
10/14/14 02:55 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You obviously have a voltmeter of some kind. Next time this problem rears it's head, start at the coil and work backwards along the system checking for resistance. When you see the ohms jump you know you've found your culprit.
[Re: RapidRobert]
#1684526
10/19/14 10:24 PM
10/19/14 10:24 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
I got to thinking, It wont matter what ignition i use, weather its petronix or electronic, it will still do this because the power going to the coil is triggered by the ignition switch, and if its causing the issue or any of the wiring from it to the coil, its still going to do this, correct? Still, jumpering the coil from the battery should eliminate this like it usually does, correct?
[Re: mopower440]
#1684529
10/21/14 02:39 AM
10/21/14 02:39 AM
RapidRobert
In the first post you said OE electronic ign. Is this the 5 pin OE ECU/4 terminal "dual" ballast? Pull the yellow wire off of the "ign" terminal on the starter relay to disable the starter and hold the coil secondary wire (dist end) 1/4 from the intake (ground) and seperate the zigzag dist pickup connector and drag the male terminal on the body connector half across the intake surface to make/break contact & see if the coil wire sparks with the ign key in "run" and have a helper hold it to "start" & if it sparks it points to the dist pickup/gap. Then take off all (might just be 1) wire from the coil neg primary and with a jumper wire with alligator clips on each end jump the coil neg terminal (not the wire you removed from it) to ground make/break like Morse Code (dragging it works) & same thing see if the coil wire sparks in "run" and in "start" if it sparks the coil/associated pri wireing is OK & points to the ECU or it associated wiring as the problem. Holler when you can
[Re: mopower440]
#1684531
10/21/14 11:41 AM
10/21/14 11:41 AM
RapidRobert
Alright, with a 2 prong "single" ballast it'll have a 4 pin ECU or a replacement 5 pin ECU & on them the 5th pin is a dummy (it dont go anywhere/infinity continuity). OE 5 pin ECU's have a functioning 5th pin & require the 4 prong (dual) ballast. At this point I should not have asked what "system" it has as that info ain't needed right now. Go ahead with the tests if you would & holler back when you can
[Re: RapidRobert]
#1684532
10/21/14 08:50 PM
10/21/14 08:50 PM
mopower440
middle Tennessee
ok, my jumper wire i was using from the battery to coil was bad, got another wire and the coil seems to be ok. Still wont start, i think its flooded. I would have thought the plugs would be dried by now though, its been 2 days..
I think i want to replace the ignition with one that has some 'Balls' anyway. We have this spark checker at work that we use on the cadillacs, its shaped kinda like a spark plug that you clip to the side of the block and hook a plug wire to it and when you crank the engine over, a spark will jump on it if all is well. Even when my car is running, the ignition system is not strong enough to make a spark on the test tool.. any recomendations on a good strong but simple ignition? I dont have the money for a big msd crank trigger setup, so nothing like that. Would the petronix setup inside an old points distributor be stronger? Also, i want a coil that does not need a ballast..
