Hughes small block engine girdle #168445
12/16/08 01:16 PM
12/16/08 01:16 PM
Finally a HUSKER again
Moparnut426 Offline OP
So they show 2 ways to install this girdle. One way is to have the caps milled .060", and put .005" preload on the caps with the girdle, the other way is to space the girdle above the caps, and have no preload on the caps, which way would you guys prefer, or trust the most for a 500-550 hp street motor. I know Im going overboard on the bottom end, but Im a little anal on these things, and just want a very reliable engine cause I really like to play, and beat on the car. Just want you guys input.
Kasey
Re: Hughes small block engine girdle [Re: Moparnut426] #168446
12/16/08 08:37 PM
12/16/08 08:37 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
This is the way I did mine,,I milled the cap's and then milled the spotface (where the main stud's are) on all to a determined height then made hardened spacer's to fit the spot face at a thickness that gave a .005-.006 preload on the center of the cap, my machinist saw how they said to do it an agreed highly that the way I did it was far superior to their way of using a stack of hardened shim's to get the preload.
Re: Hughes small block engine girdle [Re: dartman366] #168447
12/16/08 08:46 PM
12/16/08 08:46 PM
Where hid ya get hardened washers, better yet how did ya make them, a surface grinder, or a mill?? That stuff is pretty hard.
Will the non mill way be ok on a 500 hp engine.
Kasey
Re: Hughes small block engine girdle [Re: Moparnut426] #168448
12/16/08 09:39 PM
12/16/08 09:39 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Kasey
Made the spacer's at a machine shop that I used to work at out of 4140 pre heat treat and made them a little long ,then after they were heat treated then I surface ground them to length, as far as the non-mill way, I really cannot answer that, I know I didn't like the process of installing them that way, so I went the extra step and used my own method, advantages of working in a machine shop, and liberty's I am going to miss by no longer working in one.
Re: Hughes small block engine girdle [Re: dartman366] #168449
12/16/08 09:44 PM
12/16/08 09:44 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Also, do you have any pics of the installation when finished?
Re: Hughes small block engine girdle [Re: Jeepmon] #168450
12/16/08 10:09 PM
12/16/08 10:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
not real good one's but here they are.
Re: Hughes small block engine girdle [Re: dartman366] #168451
12/16/08 10:11 PM
12/16/08 10:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
#2
Re: Hughes small block engine girdle [Re: dartman366] #168452
12/16/08 10:14 PM
12/16/08 10:14 PM
it almost looks like you used a grinder to machine off the caps. Did ya mill, or grind??
Re: Hughes small block engine girdle [Re: Moparnut426] #168453
12/16/08 10:18 PM
12/16/08 10:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
milled, look closely and you will see the mill mark's, I think you are seeing a glare in the photo, these pic's show the supplied shim's, I thought I had pic's of the one's I made but I guess not.
Re: Hughes small block engine girdle [Re: Moparnut426] #168454
12/17/08 12:00 AM
12/17/08 12:00 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Note the notches to clear the rods.
I have not run this one yet...but when I do know it will feel like Christmas
Re: Hughes small block engine girdle [Re: Moparnut426] #168455
12/17/08 03:39 AM
12/17/08 03:39 AM
Cab_Burge Online work
Cab_Burge  Online Work
The stock main caps are probally good to 550Hp+ using a good set of nmain studs, 9 secondPhils motor made over 500 hp on pump gas and he has been beating on it for over three years now, plus two years of hitting it with 250Hp of NOS now and then
Re: Hughes small block engine girdle [Re: Cab_Burge] #168456
12/17/08 12:56 PM
12/17/08 12:56 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Thanks for the pictures..
Re: Hughes small block engine girdle [Re: Jeepmon] #168457
12/17/08 01:32 PM
12/17/08 01:32 PM
No body has said if I need to mill them yet, Is it necessary. I was going to accially surface grind them, shat should work.
Kasey
Re: Hughes small block engine girdle [Re: Moparnut426] #168458
12/17/08 01:51 PM
12/17/08 01:51 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Will a girdle help with this??
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Hughes small block engine girdle [Re: Moparnut426] #168459
12/17/08 05:09 PM
12/17/08 05:09 PM
ThermoQuad Offline
ThermoQuad  Offline
My engine builder used the method #2 procedure where you mill the crown of the caps and align hone. He did do some other trickery that escapes me at the moment.
Re: Hughes small block engine girdle [Re: Troy] #168460
12/17/08 06:09 PM
12/17/08 06:09 PM
Thats whats its designed to help keep from happening.
Kasey
Re: Hughes small block engine girdle [Re: Moparnut426] #168461
12/17/08 08:56 PM
12/17/08 08:56 PM
Also, My kit came with a bolt on the tight area under the oul pump. Does anyone know what length stud is supposed to be there, and If I call ARP will they send me 1 stud, and nut?? I have all studs in my other engine, and want the same on this one.
Im conserned that no one here has ever just used the 1st method to put the girdle on, and I am forced to go ahead and have the caps milled/machined and do it the second way as It makes more sence having a little preload on the caps.
Thanks Guys
Kasey
Re: Hughes small block engine girdle [Re: Moparnut426] #168462
12/18/08 09:51 AM
12/18/08 09:51 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Does it though?? You are removing some meat off the cap and then preloading it with a piece of steel plate. I got to wonder if you are really seeing much strengthing for all that work. I always thought the primary job of the girdle was to positively locate the tops of the studs to keep the caps from moving. I think both methods do that.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Hughes small block engine girdle [Re: CJK440] #168463
12/18/08 01:15 PM
12/18/08 01:15 PM
Thats what I thought too, THats what I was questioning, Im might have just changed my mind.
Kasey
Re: Hughes small block engine girdle [Re: Moparnut426] #168464
12/18/08 01:58 PM
12/18/08 01:58 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
Kasey,
I would say that over half of the ones we sell get put on by guys at home without a mahcine shop. Anything that ties the caps together will help. We like this better than the 4 bolt cross bolt mains. Drilling and notching for the crossbolts weakens the block about as much as the 2 extra bolts help it. We have had very good luck running the girdles on the small blocks. Several have dyno's well over 600HP and are still running strong with of sign of cap walk.
If you need any help installing it you can call us anytime,
Merry Christmas!
Kevin
