Early B-Body Speedometer Cable with 1966 or Later 727 #1684471
10/11/14 02:02 PM
10/11/14 02:02 PM
Utah, USA
1964superstock Offline OP
Utah, USA
Not sure if this has been posted before, but I could not find it on Moparts or anywhere else and had to figure this one out myself. If you happen to need a retrofit speedometer cable for an early 1962-1965 B-Body using 1966 and later 727 Torqueflite, I found a perfect part that fits. Hold on to your chairs, it is for a '67-'68 CAMARO!!!
The original speedometer cable for my 1964 Plymouth Savoy with the pushbutton 727 measures 68 1/2 inches. I found that the 1967-68 Camaro originally uses a 69 inch Speedometer Cable Assembly. I ordered one on eBay, and installed it yesterday. It fits perfect and fits the 727 and speedometer like a glove. FYI...I tried the local Napa, Autozone, Oreilly's, ect, also, and none had a cable even close to the right length, so back to the internet for parts. This might save you some time, try these links:
Part numbers on the speedometer cable is SC-72 and W-871.
http://www.ebay.com/itm/1967-1968-Camaro...p;vxp=mtr[/url]
http://www.rickscamaros.com/camaro-speed...-1967-1968.html
http://www.restorationperformance.com/servlet/the-158990/67-dsh-68-69"-Speedo-Cable/Detail
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: 1964superstock] #1684472
10/11/14 07:42 PM
10/11/14 07:42 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Someone posted a part number here for a Pioneer cable a few years back. Saved my bacon!
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: GY3] #1684473
10/11/14 08:29 PM
10/11/14 08:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The oft-cited Pioneer CA-3004 cable is 83" long.
http://www.oreillyauto.com/site/c/detail/PIO0/CA3004.oap?keyword=ca3004
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: John_Kunkel] #1684474
10/11/14 10:19 PM
10/11/14 10:19 PM
Utah, USA
Utah, USA
Not sure about your exact application, but an 83 inch cable is WAY TOO LONG for a early B-Body. That is how I found the 69 inch speedo cable which is readily available for 67-68 Camaros. It is all aftermarket stuff made in China anyway, so really does not matter what you use.
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: 1964superstock] #1684475
10/12/14 01:19 AM
10/12/14 01:19 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Amazon has several as well, just search for 69 Camaro. They seem to measure 68" there. $15- $40
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: NTOLERANCE] #1684476
10/12/14 05:39 PM
10/12/14 05:39 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
When we put the late 727 in the 62 300 Steve at Imperial services sent my kid one free.The guy always takes care of us.Rocky
Chrysler Firepower
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: 1964superstock] #1684477
10/14/14 04:34 PM
10/14/14 04:34 PM
Winnipeg, MB, Canada
71Plym Offline
71Plym  Offline
Thanks 1964SS, that should save me some head scratching with my 65 Belvedere.
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: 71Plym] #2013372
02/16/16 08:08 PM
02/16/16 08:08 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I know it's been a while since this was posted but used the 67-69 Camaro in my '63 Dodge today with '70's transmission and it worked PERFECT! Steel ends and much shorter than the Pioneer that shot craps.
$35 through Ricks Camaro parts.
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: GY3] #2016121
02/20/16 04:16 PM
02/20/16 04:16 PM
Utah, USA
Utah, USA
I'm happy the advice about using a 67-68 Camaro speedometer cable in a 62-65 B-body worked for you. One of these is still working great in my '64 Plymouth Savoy, which uses a 66-up 727.
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: 1964superstock] #2016132
02/20/16 04:31 PM
02/20/16 04:31 PM
Wisconsin
1964maxwedge Offline
Wisconsin
Brewers performance sells them part # sc1605 for 39.95 that's where I bought mine.look under the 4 speed parts then under the speedometer parts.
Re: Early B-Body Speedometer Cable with 1966 or Later 727 [Re: 1964maxwedge] #2016152
02/20/16 05:11 PM
02/20/16 05:11 PM
Utah, USA
Utah, USA
From Brewer's Website:
http://www.brewersperformance.com/proddetail.asp?prod=SC1605
SC1605 SPEEDOMETER CABLE 1962-65 B-BODY USING 1966/LATER TRANSMISSION
New speedometer cable fits 1962-65 B-body cars when using 1966 & later transmissions. Correct black housing, 75" long. Firewall grommet NOT included.
75 inches is too long in my opinion as the original was 68.5 inches long. Problem is making it fit and work with the extra length that is not needed. I would get the 69 inch speedometer cable for '67-'68 Camaro and call it good. It works.
