Trans Fluid Type? #168433
12/16/08 07:34 AM
12/16/08 07:34 AM
Tony440 Offline OP
Tony440  Offline OP
What type of trans fluid should be used in a 1999 Chrysler 300M with the 3.5 V6 and auto stick, and how many quarts is the capacity? Thanks!
Re: Trans Fluid Type? [Re: Tony440] #168434
12/16/08 10:14 AM
12/16/08 10:14 AM
Tony440 Offline OP
Tony440  Offline OP
Anyone?
Re: Trans Fluid Type? [Re: Tony440] #168435
12/16/08 12:13 PM
12/16/08 12:13 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I was waiting for the peanut gallery to chime in with 40 reason to use anything other than mopar type4. If you must choose any other only amasoil synthetic will work as well. If you want to replace your trans soon please feel free to use whatever you want other than type4 or the amsoil.
Many dealers will sell you type4 in bulk if you supply the container.
Re: Trans Fluid Type? [Re: ThermoQuad] #168436
12/16/08 12:17 PM
12/16/08 12:17 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
atf-4 is the recommened fluid and it is true other fluids as in dextron will affect the shift quailty however I have seen 604s go for years with the wrong fluid in them BUT I would use the correct fluid.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Trans Fluid Type? [Re: dusturbd340W5] #168437
12/16/08 12:35 PM
12/16/08 12:35 PM
Tony440 Offline OP
Tony440  Offline OP
Thanks!
Re: Trans Fluid Type? [Re: ThermoQuad] #168438
12/16/08 04:04 PM
12/16/08 04:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
So, what you're saying is that transmissions built before the introduction of the plus fluids could be expected to "fail soon"?
Re: Trans Fluid Type? [Re: John_Kunkel] #168439
12/16/08 09:46 PM
12/16/08 09:46 PM
moparx Offline
moparx  Offline
i got 300k[ + ] on my old 95 caravan using dexron3 and the only failures was a couple of input/output sensors. the trans still works good. we had it crusing the boneyard the other day in the snow.....
