67 Dart drum brake swap #1684233
10/10/14 02:39 AM
10/10/14 02:39 AM
Australia
P
Project kickin A Offline OP
P
Australia
planing to change my 67 Dart from non boosted drum brakes to mid 70s disc brakes and keep it non boosted, do I need to change the master cylinder and or the brass block thats on the chassi rail?
Re: 67 Dart drum brake swap [Re: Project kickin A] #1684234
10/10/14 05:23 AM
10/10/14 05:23 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Def. change the MC to a disk/drum setup. How are you doing this? Aftermarket, Cordoba setup, 68-71 disks? Makes a big diff.
-Daty
Re: 67 Dart drum brake swap [Re: Project kickin A] #1684235
10/10/14 11:48 AM
10/10/14 11:48 AM
On my 65 dart I went from non power 9" drums to 74 A discs/10" BBP (2&1/4"?) rear drums with a truck 1&1/8" (iirc) alum dual bowl MC & kept the OE splitter block & ran the forward bowl straight to the rear as Eberg touted but with no added adjustable prop valve & it performed flawless. It did lockup the rears first if I hit it hard and admittedly this was regular easy driving around town/no panic stops needed. -people say you need the larger bowl half for the discs but for enthusiasts like ourselves who check the fluid level regularly the added insurance of a larger bowl ain't an absolute as it is not in danger of running dry like it might be with granny in a DD (liabilty issues for Ma) and on the MC bore dia people have had to stand on the pedal with a MC of too large a bore but I never ran into that and I dont think you will either in this case. IF you need a longer front flex hose the 78 Volare hose is longer & just cut off half of the metal bracket that is crimped in the middle of the hose (you'll see when you look at it).
Re: 67 Dart drum brake swap [Re: Project kickin A] #1684236
10/10/14 01:57 PM
10/10/14 01:57 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Yes, I'd change them both. If possible use the distribution/proportioning block/valve from the disc brake donor car.
You upgrading the rears to large bolt pattern brakes as well?
