440 stalling out
#1684211
10/10/14 01:49 AM
10/10/14 01:49 AM
Posts: 104 Arkansas
Nimbus426
Arkansas
I have a '73 440 with a holley 4bbl that ran pretty good until recently. If I start the engine cold it will start right up and idle for about 30 seconds and then die. If I try to start it afterwards, it won't start unless I pump the gas a few times (I normally don't have to pump the gas at all to get it started so this is new). When it does start it just putters and dies again seconds later. The fuel pump is pumping fuel fine. I checked for obstructions in the fuel line. The I put a new fuel filter on hoping it would help, but it didn't. So the filter is clean. The carburetor is squirting fuel. I haven't touched the mixture screws because it was tuned fine the other day. Any thoughts? Thank you.
-ERIC
Re: 440 stalling out
[Re: RapidRobert]
#1684213
10/10/14 02:13 AM
10/10/14 02:13 AM
Posts: 104 Arkansas
Nimbus426
Arkansas
I timed the engine and adjusted the mixture screws several months ago and it has run fine until this started happening the other day. I haven't hooked up a vacuum gauge to it yet. I will give the carb cleaner a try.
-ERIC
[Re: Nimbus426]
#1684214
10/10/14 02:23 AM
10/10/14 02:23 AM
RapidRobert
You might go slightly richer on the mixture screws.
