Mike get ahold of me this weekend the drb III replacement is a star scan that manufacturing and service use now for MY 2004 to present. It sounds like it is doing what is called a 2 -1 bump stop. as far as quick learn is concerned if the battery hasn't been disconnected or dead, The cvi's (clutch volouim Index) are always updating everytime the the trans shifts thru all upshifting and down shifts events. this is based on time ver's pressure switch closing time.
I am in St. Louis right now will be home friday night. good luck Jim and Ryan
