That is the combo I want to put together. The car is a 1965 Dodge Dart. Due to the tall intake and carbs, fitment under a stock hood with a 3.5 inch air cleaner is way too high.
So I figure the solution is to go to the shaker hood system and use the gen2 Hemi base plate ,air cleaner and scoop.
Has anyone done this? I am in need of some measurements to figure this out. I need:
Air grabber base of flange ( Where the carbs mount) to top of air cleaner measurement
Center of a gen 2 hemi or 440 6 pack crank to the top of the air cleaner
Width and length of the hole I am going to have to cut in the hood
I hope this will work, as I think any other combo would look out of place on this car.
Thanks, Greg
