Shaker/early A /2x4 genIII Hemi? #1683779
10/09/14 09:27 AM
10/09/14 09:27 AM
gregsdart Offline OP
That is the combo I want to put together. The car is a 1965 Dodge Dart. Due to the tall intake and carbs, fitment under a stock hood with a 3.5 inch air cleaner is way too high.
So I figure the solution is to go to the shaker hood system and use the gen2 Hemi base plate ,air cleaner and scoop.
Has anyone done this? I am in need of some measurements to figure this out. I need:
Air grabber base of flange ( Where the carbs mount) to top of air cleaner measurement
Center of a gen 2 hemi or 440 6 pack crank to the top of the air cleaner
Width and length of the hole I am going to have to cut in the hood
I hope this will work, as I think any other combo would look out of place on this car.
Thanks, Greg
Re: Shaker/early A /2x4 genIII Hemi? [Re: gregsdart] #1683780
10/09/14 10:36 AM
10/09/14 10:36 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Shaker would look bad (and bad as in terrible not bad as in cool) on that car. It is VERY big. Those A-bodys look good w/ a "Hemi" scoop. Like this one. Here is a post to help you decide.
https://board.moparts.org/ubbthreads/show...amp;Search=true
Coming soon!!!!
