1974 charger no headlights #1683656
10/09/14 01:27 AM
10/09/14 01:27 AM
Albuquerque, new mexico
moparvinson Offline OP
I am trying to finish my sons 74 charger and I have no headlights? the fender mounted turn signals light up so I now it is getting power to the front harness. is there a headlight relay that could be bad or headlight switch? Thanks.
Re: 1974 charger no headlights [Re: moparvinson] #1683657
10/09/14 01:31 AM
10/09/14 01:31 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You can buy headlights at many auto parts stores.
Re: 1974 charger no headlights [Re: Kern Dog] #1683658
10/09/14 01:33 AM
10/09/14 01:33 AM
the bulbs are all good. tested them in my charger to rule that out
Re: 1974 charger no headlights [Re: Kern Dog] #1683659
10/09/14 01:34 AM
10/09/14 01:34 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I was kidding with you.
I've had this happen before. Try using a different dimmer switch. The headlight switch doesn't fail very often. The 70 Charger used a headlight relay due to the electric headlight doors. The 74 model may not have a headlight relay though.
Re: 1974 charger no headlights [Re: moparvinson] #1683660
10/09/14 01:42 AM
10/09/14 01:42 AM
(Headlight) Power flows from the HL switch to the dimmer switch/to bulkhead/out to headlights & start with the dimmer switch, which is either on the floor or in the dash. It has (3) terminals: the power in, power out to the low beams and power out to the high beams which lights up the low beam filaments at the same time. www.mymopar.com will have the colors for you. See if you have fire at the (2) bulkhead terminals (1 for low beams/1 for high/low together) & since you have neither I'd say start at the dimmer switch & if it has power in then work downstream (2 "out" dimmer switch terminals to bulkhead). EDIT I ain't familiar with a headlight relay & how it operates
Re: 1974 charger no headlights [Re: Kern Dog] #1683661
10/09/14 01:49 AM
10/09/14 01:49 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
U funny guy.
Yep probably either the dimmer switch or H/L switch
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1974 charger no headlights [Re: moparmarks] #1683662
10/09/14 02:27 AM
10/09/14 02:27 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
I'd guess high beam switch.
Re: 1974 charger no headlights [Re: Mr_fixit] #1683663
10/09/14 11:44 AM
10/09/14 11:44 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If the bulbs are out check for power and ground at the bulb plugs.If not there go to the bulkhead connector.then to the dimmer and finally the switch.Id say dimmer is either bad or not hooked up.Do you have a service manual?If not get one.Rocky
Chrysler Firepower
Re: 1974 charger no headlights [Re: therocks] #1683664
10/09/14 04:37 PM
10/09/14 04:37 PM
P
Paul_Fancsali Offline
P
Check and see if ground wire is on tight out by radiator support bet its the problem. This is wire generally attached to the battery ground ire connection on rad support
Re: 1974 charger no headlights [Re: Paul_Fancsali] #1683665
10/10/14 02:22 PM
10/10/14 02:22 PM
Creedmoor, NC, USA
74Charger Offline
74Charger  Offline
Creedmoor, NC, USA
Seen this as the problem more than once!
Re: 1974 charger no headlights [Re: 74Charger] #1683666
10/11/14 05:05 PM
10/11/14 05:05 PM
you nailed it Paul! I found the loose ground behind the battery, all lights work great. Thank you all for the help.
