Re: 727 trans brake ID
[Re: '72CudaRacer]
#1683626
10/08/14 09:39 PM
10/08/14 09:39 PM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
Its a Tranzact pro brake. Copy of the Griner Engineering model, 1222G20 or could be the clean neutral model with a neutral after 3rd position. You have to push the brake button in Reverse to back up. www.tranzactofindy.comJohn
[Re: DusterW2]
#1683627
10/09/14 07:06 PM
10/09/14 07:06 PM
Posts: 2,082 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Thanks John. It does require that the TB button be pushed in order to back up. Are both models from Transact like that or just the later model one? This car has been nothing but surprizes. A friend traded for it, and I'm tring to help him get it to his liking. It had a Derale deep oil pan (extreamly deep, w/cooling fins in the bottom) on this trans, but no filter extension ![](/ubbthreads/images/graemlins/shruggy.gif) . Thanks for your help. ![](/ubbthreads/images/graemlins/thumbs.gif) At least I know what we got now. Brian
[Re: '72CudaRacer]
#1683628
10/09/14 07:23 PM
10/09/14 07:23 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
when I got my brake from Joe at transact he had a pro brake that you have to push the TB button for rev and a sportsman brake that you did not.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: DusterW2]
#1683630
10/10/14 06:58 PM
10/10/14 06:58 PM
'72CudaRacer
Mooresburg, Tn
Any way to tell if this is a TCI or Transact brake? How would you tell them apart? It does have the large soleniod like the TCI picture and also the screw and double washer set up over the seperator plate where the accumalator spring would normally be. I don't see any logo, name or part numbers on it. ![](/ubbthreads/images/graemlins/scope.gif) Thanks, Brian
[Re: '72CudaRacer]
#1683631
10/10/14 07:33 PM
10/10/14 07:33 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
The TCI Brake I had, had a part number on it. The tranzact brakes I have do not have a part number or serial number on them.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
