Steering column help #1683413
10/08/14 03:58 PM
10/08/14 03:58 PM
Hazlet nj
Joemoy29 Offline OP
Joemoy29  Offline OP
Hazlet nj
hello, my car was manual steering and i just installed the firm feel stage three box, (great company to deal with) i pulled the manual column out of the car, i was able to get a donor column from a power steering car, is there any tips of plan of attack to dismember my manual column and swap the shaft for the shorter power one? Thanks for any help
Joe
Re: Steering column help [Re: Joemoy29] #1683414
10/11/14 02:57 PM
10/11/14 02:57 PM
Battle Ground, Washington
Rapom65 Offline
Rapom65  Offline
Pretty straight forward remove and replace procedure. If you have never worked on columns before a factory service manual would be highly recommended. There are lots available on-line for free. While you have it blown apart consider replacing the sloppy stock bushing setup with a column support bearing.
Re: Steering column help [Re: Rapom65] #1683415
10/11/14 03:00 PM
10/11/14 03:00 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
That's what I did when I replaced my column shaft. Except, when it all went back together, I forgot something, so now my turn signal lever rotates a full 90 degrees before engagement.
Re: Steering column help [Re: MuuMuu101] #1683416
10/11/14 09:47 PM
10/11/14 09:47 PM
IN
ahy Offline
ahy  Offline
IN
x2 on the factory service manual.
Also, if you pull the pot coupling apart, mark the orientation or indexing. If it is re-assembled 180 degrees off, it will be impossible to center the steering wheel. The coupling is easy to rebuild with a simple kit and its a good idea to get it cleaned, checked and re-lubed.
