School me on Original Keys 1965 to 1972 #1683385
10/08/14 03:38 PM
10/08/14 03:38 PM
Bristol, CT
RalphsRapidTrnst Offline OP
Bristol, CT
I am looking for help with what are the proper keys for the following years 1965, 1966 1967 1968 1969 1970 1971 & 1972.
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: School me on Original Keys 1965 to 1972 [Re: RalphsRapidTrnst] #1683386
10/08/14 03:39 PM
10/08/14 03:39 PM
Bristol, CT
Bristol, CT
1966 1967 & 1968 ?????
Re: School me on Original Keys 1965 to 1972 [Re: RalphsRapidTrnst] #1683387
10/08/14 03:40 PM
10/08/14 03:40 PM
Bristol, CT
Bristol, CT
1965 Trunk. Ingition is the same as 1966 ????
Re: School me on Original Keys 1965 to 1972 [Re: RalphsRapidTrnst] #1683388
10/08/14 03:41 PM
10/08/14 03:41 PM
Bristol, CT
Bristol, CT
1969 1970 1971 & 1972 option one
Re: School me on Original Keys 1965 to 1972 [Re: RalphsRapidTrnst] #1683389
10/08/14 03:42 PM
10/08/14 03:42 PM
Bristol, CT
Bristol, CT
1969 1970 1971 & 1972 Option Two Door & Ingnition
Re: School me on Original Keys 1965 to 1972 [Re: RalphsRapidTrnst] #1683390
10/08/14 03:43 PM
10/08/14 03:43 PM
Bristol, CT
Bristol, CT
1969 1970 1971 & 1972 Option Two Trunk.
Re: School me on Original Keys 1965 to 1972 [Re: RalphsRapidTrnst] #1683391
10/08/14 03:45 PM
10/08/14 03:45 PM
Bristol, CT
Bristol, CT
So what are the proper keys for the following years 1965, 1966 1967 1968 1969 1970 1971 & 1972.
Re: School me on Original Keys 1965 to 1972 [Re: RalphsRapidTrnst] #1683392
10/09/14 12:13 AM
10/09/14 12:13 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
The Pentastar-shaped head was not introduced until 1970 -- to fit the column-mounted lock cyl.
Rick
Re: School me on Original Keys 1965 to 1972 [Re: Rick_Ehrenberg] #1683393
10/09/14 03:26 AM
10/09/14 03:26 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Rick
Correct,
69 uses the rectangle head, same at 68 and earlier, but Mopar changed vendors for 69 (Yale I believe) and the long milled slot is in a different location than previous and all the teeth are different heights so the lock pins do not interchange.
Re: School me on Original Keys 1965 to 1972 [Re: sthemi] #1683394
10/09/14 04:53 AM
10/09/14 04:53 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: School me on Original Keys 1965 to 1972 [Re: sthemi] #1683395
10/09/14 04:54 AM
10/09/14 04:54 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Got a 67 BCuda with a pentagon head, round trunk, been that way for years. Must have been something done way back in the day.
-Daty
Re: School me on Original Keys 1965 to 1972 [Re: 6bblgt] #1683396
10/09/14 05:01 AM
10/09/14 05:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The Pentastar shaped head debuts with the 1969 EP (1969 series "primary") & ES (1969 series "secondary") codes.
Although the generic key blanks (Y-152 ignition & Y-149 trunk) are the same for '68 & earlier years - the set up in reference to the "groove" is what changed the pin heights for the EP/ES coded keys.
Re: School me on Original Keys 1965 to 1972 [Re: 6bblgt] #1683397
10/09/14 06:23 AM
10/09/14 06:23 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I have original keys with "A", "B", "I", & "Y" stamped on them, I do not know who the manufacturer or which ones were factory supplied with each year.
B = Briggs & Stratton, I = Ilco, Y = Yale
Re: School me on Original Keys 1965 to 1972 [Re: 6bblgt] #1683398
10/09/14 10:48 AM
10/09/14 10:48 AM
Bristol, CT
Bristol, CT
Thank you to all What about 1965 and 1966? are the same as 1967?
Re: School me on Original Keys 1965 to 1972 [Re: RalphsRapidTrnst] #1683399
10/09/14 11:27 PM
10/09/14 11:27 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Related thread from last year:
WHERE CAN I BUY ORIGINAL TYPE CHRYSLER KEY BLANKS
https://board.moparts.org/ubbthreads/show...amp;Search=true
Common sense is a flower that does not grow in everybody's garden
Re: School me on Original Keys 1965 to 1972 [Re: Daty Rogers] #1683400
10/10/14 01:41 AM
10/10/14 01:41 AM
Alberta
N
NEVjr Offline
NEVjr  Offline
N
Alberta
-Daty
same for my dads 67 barracuda, originally an arizona car, he got it in the mid 80s, we always assumed they were original.
my 62 valiant (canadian model, not a plymouth) came to me with pentastar head with a B under the star and 770U in the top part for the doors, and a pentastar with a B for the ignition, and a round one with marks worn off for the trunk.
it also has a set of pentastar knock offs with curtis on the star. the door keys hve a different set of grooves than the ignition
the car was delivered in april of 1962, so i guess the keys arent original, if wikis sept 1962 adoption of the pentastar logo is right
Re: School me on Original Keys 1965 to 1972 [Re: NEVjr] #1683401
10/12/14 09:31 AM
10/12/14 09:31 AM
New Jersey
P
Powerflow Online content
Powerflow  Online Content
P
New Jersey
My father's '65 Coronet, bought new, came with a pentastar-shaped ignition/door key and a round trunk key that was flat on one side (no grooves).
The grooves on the sides of the key are called 'keyways'. The letter on the key refers to which keyway it is.
Re: School me on Original Keys 1965 to 1972 [Re: Powerflow] #1683402
10/12/14 03:39 PM
10/12/14 03:39 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
Here is pic of the Ilco catalog. 1966 was a separate year for the trunk key. The newer key will work though as it has a wider groove.
Ign is 1764P & Trunk is 1766S
1959 -1964 were a side bar lock & there were grooves on only one side of the blank.
Go to a locksmith, don't screw around with the hardware store or the big box store.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
