Dana 60 ?? #1683339
10/08/14 12:00 PM
10/08/14 12:00 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I'm looking ata a Dana that's for sale and the guy says its out of a truck but the thing has a pinion snubber. I was under the impression truck Dana's only had the pad but weren't drilled and did not have snubbers attached.
Re: Dana 60 ?? [Re: Stanton] #1683340
10/08/14 12:06 PM
10/08/14 12:06 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
That will be out of a car originally. It may have gotten under a truck at some point but only car rears had the pinion snubber.
Look for the BOM build of material number on the passenger side tube.
It should be a few inches out from the center section. Will be similar in forum of 602957-1 and should have some dates.
That BOM number will tell you what you need to know about the rear and how it was built from the factory.
Matt
Re: Dana 60 ?? [Re: mattsmopars] #1683341
10/08/14 12:17 PM
10/08/14 12:17 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i had a 72 dodge truck dana 60 with a pinion snubber--probably pretty rare but it has me looking under every 72 at the junk yard now.....
Re: Dana 60 ?? [Re: mattsmopars] #1683342
10/08/14 12:17 PM
10/08/14 12:17 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Here is some more information:
Re: Dana 60 Bill of Materials list
http://www.therangerstation.com/tech_library/Dana_BOM_numbers.html
For Mopar only:
Bill of Materials Numbers:
68-69 B body 3.54 Powr-Lok 602957-1, -2, -3, -4
4.10 Powr-Lok 602957-5, -6
69.5-70 B body 3.54 Powr-Lok 603109-1, -2
4.10 Powr-Lok 603109-3, -5
4.56 Powr-Lok 603109-6, -7, -8
70-72 B body 3.54 Trac-Lok 603222-1, -2
4.10 Trac-Lok 603222-3
4.56 Trac-Lok 603222-4
75-77 B body 5.13 Powr-Lok 603347-2
5.38 Powr-Lok 603347-1
69-71 E body 3.54 Powr-Lok 603080-1, -2, -4
4.10 Powr-Lok 603080-3, -5
4.56 Powr-Lok 603080-6, -7
70-72 E body 3.54 Trac-Lok 603226-1, -2
4.10 Trac-Lok 603226-4
74 E body 5.38 Powr-Lok 603425-1
77-78 Retail 4.10 Trac-Lok 603831-1
Maint.
67-70 D200/W200 Std 602423
68.5-70 D200/W200 Std, Powr-Lok 602010
69.5-72 D200/W200 Std, Powr-Lok, Trac-Lok 603016
71.5-75 D200/W200 Std, Trac-Lok 603236
76 D200/W200 Std, Trac-Lok 603769
77 D200/W200 Std, Trac-Lok 603775
78 D200/W200 Std, Trac-Lok 603892
71-75 D200/W200HD Std, Trac-Lok 603237
76-78 D200/W200HD Std, Trac-Lok 603647
70-71 B300/M300 Std, Powr-Lok, Trac-Lok 603160
71.5-74 B300/M300 Std, Trac-Lok 603313
74.5-75 B300/M300 Std, Trac-Lok 603516
76 B300/M300 Std, Trac-Lok 603645
76.5 B300/M300 Std, Trac-Lok 603768
77-78 B300/M300 Std, Trac-Lok 603774
78 B300 Maxi Std 603832
The higher ratio gearsets shown in the table of BoM numbers may be Pro-Stock applications. Also, the application years shown seem to be calendar year, not model year (there were no '69 E bodies).
Axle shaft dimensions vary in Dana 60 axles. Dimensions of semi- floating (passenger car type) axles shafts are shown below. Shaft lengths are measured from the outer flange face to the inboard end of the shaft. Note that the right axle shaft is always shorter than the left, so unlike the Chrysler 8 3/4" axle, Dana 60 axle shafts will not interchange side-to-side.
BoM Dia.-splines L shaft R shaft
602957 1-1/2"-23 29-21/32" 28-9/32"
603109 1-1/2"-35 29-21/32" 28-9/32"
603222 1-1/2"-35 31-5/64" 29-11/16"
603347 1-1/2"-35 28-7/16" 27-1/16"
603080 1-1/2"-35 30-7/16" 29-1/16"
603226 1-1/2"-35 30-7/16" 29-1/16"
603425 1-1/2"-35 24-7/16" 23-1/16"
603831 1-5/16"-30 32-5/8" 32-5/8"
The truck dana 60 housing are just round across the top of the pinion.
Matt
Re: Dana 60 ?? [Re: mattsmopars] #1683343
10/08/14 12:32 PM
10/08/14 12:32 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
guess i must have been having one of those dreams where i cut the truck axle ends off and welded on the passenger car ends to make a E body size dana 60.....
Re: Dana 60 ?? [Re: savoy64] #1683344
10/08/14 12:54 PM
10/08/14 12:54 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Apparently it's a "non posi" rear end. With no more info, what do you think its worth ??
Re: Dana 60 ?? [Re: Stanton] #1683345
10/08/14 01:32 PM
10/08/14 01:32 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
There was a guy at a Mopar show 10 or so years ago selling a full floater Dana housing with the snubber mount. He said that when Danas were no longer used in cars after '72 they used up the center castings by putting them in trucks. IIRC this one was out of a 1 ton B-series box van
Re: Dana 60 ?? [Re: savoy64] #1683346
10/08/14 01:51 PM
10/08/14 01:51 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I am in no way saying that it could have never happened, I am just saying what is most case situations.
Matt
Re: Dana 60 ?? [Re: Stanton] #1683347
10/08/14 02:01 PM
10/08/14 02:01 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Overall length will determine the value. If it could be used as is in an A,B, or E body the value goes up. If it will need cut down, new ends, and new axles for your application that will hurt it.
If the housing and axles are drop in ready length wise you can pick up a power lock unit and a set of gears. Just depends on what is there as far as value goes. I have seen the cast center sections with the pinion snubber mounts go for a couple hundred dollars.
Add to that the more items that are there.
Or that's my
Matt
Re: Dana 60 ?? [Re: 446acuda] #1683348
10/08/14 02:06 PM
10/08/14 02:06 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i was told the same thing by my elderly chrysler guru---he said when something got dumped it was sent out ----he said when 426 wedge sales fell--they were restamped 413 and tossed into newports---when 8 3/4 was ended they went out in slant six 3 speed valiants and darts---they didnt want to keep inventory items that were old news....
Re: Dana 60 ?? [Re: savoy64] #1683349
10/08/14 02:23 PM
10/08/14 02:23 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I can relate to that last bit about 8.75" in Valiants. I bought a new Valiant Scamp Hardtop in 1971 with a 225/727/8.75" drive line, I wish I still had it. It was a great commuter car.
As to what a Dana 60 is worth, it depends on what you want it for. If original numbers and pinion snubbers are important then whatever the market will bear. If you want to race, then the big tube truck rears are where you begin and I can find them anywhere for $150.00 and up depending on the carrier.
BTW the center sections are cast steel not cast iron and I weld them to the tubes with 7013 rod. Then the tubes don't move and leak gear oil.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Dana 60 ?? [Re: Polarapete] #1683350
10/08/14 09:42 PM
10/08/14 09:42 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Great piece to narrow. I would say $200 especially if it has the gears you want.
Sheldon
Re: Dana 60 ?? [Re: Stanton] #1683351
10/08/14 09:52 PM
10/08/14 09:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The picture you posted is definitely a Mopar passenger car Dana 60.
Re: Dana 60 ?? [Re: DoctorDiff] #1683352
10/08/14 10:25 PM
10/08/14 10:25 PM
RUNCHARGER Offline
RUNCHARGER  Offline
That's what I was thinking Doc, the brake backing plates and axles look like Pass car stuff to me. I would hope Stanton has picked it up by now.
Sheldon
Re: Dana 60 ?? [Re: DoctorDiff] #1683353
10/08/14 10:39 PM
10/08/14 10:39 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
How can you tell from the photo? Truck axles would normally narrow down towards the ends and that can't be seen under the bags.
Re: Dana 60 ?? [Re: Stanton] #1683354
10/09/14 12:02 AM
10/09/14 12:02 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
1. Second generation passenger car pinion snubber attached with correct bolts
2. Passenger car E-brake cable anchor welded in the correct location
3. Passenger car brakes
Even the rare Dana 60 truck housing built with a pinion snubber casting, does not have these 3 features.
Re: Dana 60 ?? [Re: DoctorDiff] #1683355
10/09/14 11:45 AM
10/09/14 11:45 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I doubt many here know as much about rear ends as the Dr.Rocky
Chrysler Firepower
Re: Dana 60 ?? [Re: therocks] #1683356
10/09/14 12:39 PM
10/09/14 12:39 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I appreciate all the help. This think is all the way at the other end of the country so looking at it is out of the question. I've fired off a bunch of questions based on the info you guys have provided. If it pans out I can have this thing on my doorstep for about $350 including shipping. The only puzzling thing is the "non-posi" statement. You'd think that even if the rear had blown it would have been replaced with the same unit - the gears are 4.11's so they're likely stock!
Re: Dana 60 ?? [Re: Stanton] #1683357
10/09/14 02:27 PM
10/09/14 02:27 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I would buy all the dana 60's I could get as pictured in your original post for $350.00 at my door. You might ask for a picture with the inspection cover off to get a better idea of what is inside if possible. But it being a car unit the housing and axles are worth well more than the $350.00 so I would get the deal done and take a chance on it.
Matt
Re: Dana 60 ?? [Re: Stanton] #1683358
10/09/14 10:32 PM
10/09/14 10:32 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Probably a trac loc, they don't really look like a Sure Grip. If it's on this side of the country and you don't want it let me know the info please and I'll pick it up.
Sheldon
